Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-23-2007, 09:02 AM   #1
saz25
CF Senior Member
Support Corvetteforum!
saz25's Avatar
Send a message via AIM to saz25
Default How to store a corvette over the winter
Hi,
I am about to get my new vette in a few weeks. I live in New Hampshire, where I won't be driving my new baby that much in the winter months.
I'm starting to think winter storage. I found a local storage facility that has 10x20 garages.
Question:
1) Does it matter whether the storage garage is heated or not?
2) Do I need to put the car up on blocks or not?
Any suggestions?
Thanks,
Steve
saz25 is offline   Reply With Quote
Old 04-23-2007, 09:04 AM   #2
AORoads
CF Senior Member
AORoads's Avatar
No it doesn't matter if it's heated or not. And I'd say no, it doesn't matter if you put it up on blocks altho that may prevent a bit of flat-spotting of the tires.
Others will comment on Stabil, battery, cover, oil change, etc.
AORoads is offline   Reply With Quote
Old 04-23-2007, 09:11 AM   #3
saz25
CF Senior Member
saz25's Avatar
Thanks. Thats a good point about the battery, Stabil, etc.
I know that when I store my lawn mower and snow blower when its not in use, I add a few drops of gas stabilizer to the gas tank. Is that recommended when storing a car as well?
Should I disconnect the battery, etc.?
Thanks,
Steve
Old 04-23-2007, 09:37 AM   #4
MN CHOPPER
CF Senior Member
MN CHOPPER's Avatar
good gas, battery tender and a car cover to tuck it in for a long winters nap
MN CHOPPER is offline   Reply With Quote
Old 04-23-2007, 09:41 AM   #5
johnodrake
Moderator
johnodrake's Avatar
Johnodrake @CdrDrake johnodrake
I "store" mine for the winter, but it is in my garage where I can look after it. If I were in a really cold climate - like yours - and were storing off-site, I would remove the battery and store it at home with a tender on it.
__________________
Vita contin git. Vive com eo!
60th Anniversary 427 CE - Bone Stock.
MSM '06 415ci LS3 510rwhp, RPS, DeWitts, Pfadt Coilovers, MGW. Full 2012 GS body and interior conversion C6Z Exhaust
Leather by DSV
Powdercoating by Mike
'89 Coupe Z51, FX3, MN6
DD 05 Silverado Z71
Spring Mountain x5
Gone now but not forgotten:
Radiant Silver '09 CTS
Sebring Silver '97 LPE SC
Mille Miglia Red '73 L82 Coupe
Daytona Yellow '70 L46 Coupe
johnodrake is offline   Reply With Quote
Old 04-23-2007, 09:42 AM   #6
cthusker
CF Senior Member
cthusker's Avatar
Lets hope winter is a long long ways off! We just got done (I hope) in CT with the "Spring from Hell.........
cthusker is offline   Reply With Quote
Old 04-23-2007, 09:44 AM   #7
CodyC6
CF Senior Member
CodyC6's Avatar
I put mine in a 10X20 this past winter. Not heated is fine. As some places don't have power outlets for a battery tender, you may want to just disconnect the battery. You could pull it, and put a tender on it at home if needed. Just use the manual key procedure to get back in the car when ready to connect the battery back up.
CodyC6 is offline   Reply With Quote
Old 04-23-2007, 09:49 AM   #8
jesse12804
CF Senior Member
jesse12804's Avatar
i'M IN UPSTATE NY,same climate as you.Park it,"batterytenderize" it,put 40 lbs of pressure in the tires to avoid flat spotting and forget it.
jesse12804 is offline   Reply With Quote
Old 04-23-2007, 09:52 AM   #9
MN CHOPPER
CF Senior Member
MN CHOPPER's Avatar
there is one nice thing about puting our cars away for the winter for those of us who live in the freezer... in the spring it is like we get brand new cars all over again...
Old 04-23-2007, 09:53 AM   #10
saz25
CF Senior Member
saz25's Avatar
Thanks for all the good replies. I have another "dumb" question. What is a "tender" as it relates to the battery I guess?
Thanks,
Steve
Old 04-23-2007, 09:57 AM   #11
2008corvette
CF Senior Member
2008corvette's Avatar
Good info above, you can also put "Bounce" dryer filter sheets all over the inside of your car to keep the mice out.
2008corvette is offline   Reply With Quote
Old 04-23-2007, 09:59 AM   #12
ProfMoriarty
CF Senior Member
ProfMoriarty's Avatar
For my garaged C6:
1. Fill gas tank and add Sta-Bil (7.5 oz.); run through fuel lines.
2. Change oil and filter.
3. Park on moisture barrier
4. Inflate tires to 38 psi cold.
5. Apply sealant, wax, etc. to exterior paint.
6. Apply leather dressing to seat panel.
7. Apply vinyl dressing to interior; and to exterior black trim pieces.
8. Hook up Batter Tender. Run wire into engine compartment from underneath car and duct tape exposed wire to floor so you don't trip over it and yank it out.
9. Crack windows a bit.
10. Cover with Wolf Dustop inside car cover.
11. Wait for Spring.
ProfMoriarty is offline   Reply With Quote
Old 04-23-2007, 10:27 AM   #13
MachAll 2005
CF Senior Member
MachAll 2005's Avatar
A few more things to consider........
- Warm up engine & oil thoroughly after your oil change ... before storing.
- Scatter a few moth ***** around on the floor to help keep mice away.
- Put plastic bags on the exhaust tips to keep critters from crawling in.
- Pull up the corner of your cover monthly and LOOK......to get your blood pumping again.
- Don't start it until you are ready to get it out in the spring.
- Check over very closely for any critter nests in the engine compartment, etc.
- Check for and note any liquid drips on the floor for later investigation.
- Don't forget to remove plastic bags and pick up the moth ***** so your don't crush them and make a mess.
MachAll 2005 is offline   Reply With Quote
Old 04-23-2007, 10:31 AM   #14
jesse12804
CF Senior Member
jesse12804's Avatar
Thanks,
Steve
BATTERYTENDER.COM.It hooks up to the battery and keeps it fully charged and maintains it there;it's plugged into the wall socket.
Old 04-23-2007, 03:37 PM   #15
carjon
CF Senior Member
carjon's Avatar
I live in CT - I put stableizer in it - wash it put it under a cover and leave it outside for the winter. Seems to do fine.
carjon is offline   Reply With Quote
Old 04-23-2007, 04:32 PM   #16
Tri-Tip
CF Senior Member
Tri-Tip's Avatar
Location: Chatsworth, CA GOCC...It's not a Club, it's a Cult.
Send a message via AIM to Tri-Tip
I couldn't imagine having to live someplace where I would have to put my car away for half of the year.
Tri-Tip is offline   Reply With Quote
Old 04-23-2007, 06:54 PM   #17
50MileSmile
CF Senior Member
50MileSmile's Avatar
Everything everyone's already said, plus:
-Put a small rag under each wiper to relieve the pressure on the blades.
-Pump the clutch pedal and brake pedal each 10 times, once a month.
-Push the car forward (or back) a quarter rotation of the tires once a month to prevent flat spots.
50MileSmile is offline   Reply With Quote
Old 04-23-2007, 08:43 PM   #18
Painrace
CF Senior Member
Painrace's Avatar
Send a message via AIM to Painrace
Move to South Carolina and drive it all winter!
__________________
PAINRACE
Painrace is offline   Reply With Quote
Old 04-29-2007, 11:54 PM   #19
LV_Tom
Junior Member
LV_Tom's Avatar
Default Winterize Your Vette
Sent it to Las Vegas. I'll drive it at least once a week.
LV_Tom is offline   Reply With Quote
Old 04-30-2007, 03:26 AM   #20
longboy4
CF Senior Member
longboy4's Avatar
Default Highly foresighted.
.......its April and you're thinking about winter storage..............hmmm............... ..tell us....................Bloomberg or Hillary in '08????
longboy4 is offline   Reply With Quote
Reload this Page How to store a corvette over the winter
Tags
1999, 2000, c4, c6, corvette, store, winter
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
flame orange jeaux C3 Tech/Performance 17 05-28-2011 11:55 AM
Easy problem, but I just can not seem to fix it!! Please Help!! 68coupe C3 Tech/Performance 22 04-07-2005 11:39 AM
Tips for winter storage... secretagent54 C4 General Discussion 16 12-04-2004 04:00 PM
New owner of 86 - have some questions redsand C4 General Discussion 22 09-26-2004 06:48 PM
How often should you change your antifreeze SWCDuke C1 & C2 Corvettes 18 07-16-2003 08:32 PM
Cerra T72 Turbo Z06 Back....(long) Earl H C5 Forced Induction/Nitrous 38 06-12-2003 11:06 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
