Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - ???? > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 11-20-2006, 09:30 PM   #1
tsjolly
CF Member
tsjolly's Avatar
Default Noisy Transparent Top Problem
Just finished a little road trip to Austin, Tx. Straight away highway driving there is was no problem. But when I got in the hills I noticed my top (almost constantly) making noises I've never heard before. It would make these "creaking" noises everytime I would move the car - up, down, turning. Has anyone had this problem? Is it common? Is there a fix?
tsjolly is offline   Reply With Quote
Old 11-20-2006, 09:33 PM   #2
vette-oholic
CF Senior Member
vette-oholic's Avatar
Yes, there is a TSB fix out for it. There are some spacers that the dealer will put in and its under warranty. Im not sure the TSB #, but the dealer should know. If not, do a search on here or maybe someone can chime in with the TSB #.
vette-oholic is offline   Reply With Quote
Old 11-20-2006, 09:34 PM   #3
TrackNoob
CF Senior Member
TrackNoob's Avatar
Quote:
There is a TSB on it, Bulletin Number: 050859003 CREAK OR POPPING NOISE FROM ROOF NEAR WINDSHIELD/A PILLAR. *TT (see below) but I think that may only apply to earlier models. The most general fix is a bit of strategically applied lithium grease around the pins.
Mine was quiet as a mouse when originally installed, but after a few months it has now gotten the habit of creaking when there has been a temp change and I first start driving the car. Every time I am going to remember to fix it, it quiets down. Maybe this weekend....
Quote:
TSB# 05-08-59-003B which supersedes the 05-08-59-003A.
003B was issued 1/4/06 is document ID# 1747575.
Replace the left and right plastic guide in the roof latch striker following the procedure below. (Note that the latch is on the headliner, next to the "A" pillar.)
1. Unlatch the roof and remove the roof.
2. With a small screw driver, unlock the fingers of the guide from the striker and discard them.
3. Install the new plastic guides into the striker.
4. Install the roof.
Parts Information
P/N Description Qty
19120702 Spacer, RF Lift Off Pnl/wdo Frt Stkr (LH) 1
19121172 Spacer, RF Lift Off Pnl/wdo Frt Stkr (RH) 1
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation Description Labor Time
B9797* Replace Plastic Guide In Striker (L & R) 0.2 hr
* This labor operation is for bulletin use only. It will not be published in the Labor Time Guide.
TrackNoob is offline   Reply With Quote
Old 11-20-2006, 09:52 PM   #4
tsjolly
CF Member
tsjolly's Avatar
Thanks for the info...
Reload this Page Noisy Transparent Top Problem
Tags
19121172, 2005, c6, corvette, issue, noisy, spacer, top, transparent
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
