LS2 to LS7 swap
LS2 to LS7 swap
Anyone ever bought a crate LS7 like the one here: http://www.gmpartsdirect.com/results...ges=1&pkgid=22
and intalled it in their base C6. Is there problem doing a LS2 to LS7 swap? Obviously there would need to be a PCM reprogram, but anything else I am missing?
There was a partial writeup in one of the vette rags a few months ago.You would also need the dry sump stuff which is about a grand extra.Other than that,I don't think it's a big pain.
Get Some!
And upgrade the clutch, trans, rear diff, axles, exhaust, intake, fuel system... By the time you've invested all that time and money, you'll wish you had just bought a Z06.
I think the crate LS7 is more intended for Hot rod retrofits, like a 69 Camaro, or 32 Ford... I've seen where there is a 4 barrel carb intake coming out for it.
Supercharger alone will knock the stock c6 hp up probably 150hp or more. some say 600hp.
