Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-19-2006, 02:30 PM   #1
billywallstreet73
CF Senior Member
Default Is brake fluid and hydraulic clutch fluid the same?
My clutch fluid was low so I went to get some and the guy said that brake and clutch fluid is the same.I ended up getting nothing just because I want to make sure so I come to the vette gods for the anwser.Its time to get my car ready for the quarter soon with the first real cold front coming through south florida next tuesday.What clutch fluid does anyone recommend?
billywallstreet73 is offline   Reply With Quote
Old 10-19-2006, 02:55 PM   #2
Buffy
CF Senior Member
Buffy's Avatar
Yes, its the same stuff. Use any good quality DOT-4 fluid. Valvoline SynPower is fine and is widely available; I've had no problems with it.
P.S. Check the threads (like this one for more info on clutch fluid.
Buffy is offline   Reply With Quote
Old 10-19-2006, 04:42 PM   #3
c6vette
CF Senior Member
c6vette's Avatar
Quote:
You can use DOT 3 or 4 in the brake reservoir. 3 and 4 are interchangeable.
In the clutch reservoir, DOT 4 should be used. In both the clutch and the brakes synethics can be used because they are also interchangeable.
UNDER NO CIRCUMSTANCES SHOULD DOT 5 BE USED. IT CONTAINS SILICONE AND WILL NOT MIX WITH 3 OR 4.
I am using Prestone DOT 4 synethic in the clutch, but there are many good brands to be had. (Walmart $2.60 for 12 oz.)
c6vette is offline   Reply With Quote
Old 10-20-2006, 10:43 AM   #4
billywallstreet73
CF Senior Member
Thanks guys...I ended up using the prestone dot 4 syn and my fluid was so dark.I did the method by ranger to press in the clutch 10 times to run it through and I refilled 4 times till it was pretty much clear.I havent driven it yet but I can tell the clutch is much smoother now and it goes into gear much ,much better.Best bang for the buck ever lol.
Reload this Page Is brake fluid and hydraulic clutch fluid the same?
Tags
brake, break, breake, c6, clutch, cluthch, corvette, dot, fluid, fluit, fluud, good, hydlaulic, hydraulic, interchangable, same
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
