2nd mod (CAGS)
2nd mod (CAGS)
Hey all!
I know I am a much slower modder than most of you but I just recieved my CAGS Eliminator from Southern Car Parts. Pretty fast delievery especially considering the delivery was free! Installation was a piece of cake like everyone here has said in the past. Jacked up the rear, put down a jack stand, rolled under the car(its a little unnerving thinking that it could fall and crush me), unplugged the CAGS (which is conveniently labelled as such) plugged in both pieces of the eliminator, and WAM no more annoying Skip Shift. This morning driving to work was just great. No more forcing me to bog down the engine if Im stuck behind a slow car. Best bang for the buck enjoyment mod out there for anybody that doesnt have it yet. I know that most of you do, but if you have a MN6 get off your butt and get one!
Moderator
Received 3,570 Likes
Originally Posted by rjward
Hey all!
Hey all!
Originally Posted by johnodrake
I have been driving with CAGS for over 8 years now and it rarely bothers me. Just stay in 1st a bit longer and it never happens...Just my .02
You must not have much in the way of traffic there in Sterling VA. A little farther up the NE coast here in the greater Philly area there is NO WAY to avoid CAGS making you crazy. It's a cheap, simple solution and even if it's a potential annoyance I don't see any reason NOT to do it. I've had CAGS on since the 2nd day(4+ months ago) and have never seen a CEL. And that's my .02.
Originally Posted by rmp
Wait until your check engine light comes on, then you won't be so happy. That's what happened to a number of us and I had to remove the CAGS eliminator to get rid of it.
Originally Posted by TheKomoman
You must not have much in the way of traffic there in Sterling VA. A little farther up the NE coast here in the greater Philly area there is NO WAY to avoid CAGS making you crazy. It's a cheap, simple solution and even if it's a potential annoyance I don't see any reason NOT to do it. And that's my .02.
Originally Posted by mpuzach
Hmmm...I hadn't heard that one before. I've had a CAGS eliminator on my '05 since new and I've had zero problems.
Location: In the mountains of VA surrounded by roads that any of you would be envious of!
After reading multiple threads on the subject, I'm convinced it's just a matter of personal preference. CAGS has never engaged on my car and I don't drive hard.
Some have gone bad and caused a CEL. All it is, is a 2.2K Ohm resistor inside a plasic box with the wiring pigtals.
Want something with no connections to fail. Just use a Radio Shack resistor bent into a U-shape, inserted into the female CAGs connector.
Tape it up, zip tie it to the trans tab. You'll never touch it again and only spent fitty cent.
http://www.installuniversity.com/ins...adio_shack.htm
Cags
Fellas,
You don't need a "CAGS Eliminator" plug-in thinggy, or the RadioShack 2.2k ohm resister for you cheapskates. When you take the car to a shop for a "tune" using any of the popular software programs such as LS2EDIT, just tell 'em to toggle the CAGS function off. Presto! No more CAGS. Export 'Vettes don't have it y'know, and Bowling Green certainly doesn't install any additonal hardware or bits on those cars.
Originally Posted by stapleking
Fellas,
