Will these wheels fit correctly on my narrow body C6?
Old 10-31-2022, 02:14 AM
austin97
1st Gear
austin97's Avatar
Default Will these wheels fit correctly on my narrow body C6?
I own a 2008 C6 Base and have been researching wheel setups. Found a set of ESR wheels I really like but am kind of iffy about how they might look on the car. Wanted to know if these wheels would fit correctly and not stick out from the fenders and I’m also looking for a good tire setup recommendation for these wheels if they fit correctly. The car comes stock with 18s but I really was wanting to switch to 19s if possible here are the specs for the wheels I was wanting to purchase.
front: 19x8.5 +30 offset
rear: 19x9.5 +35 offset
ESR SR01 Wheels
Old 10-31-2022, 06:01 AM
jamieo
jamieo's Avatar
No.The fronts will stick out about 1" farther and the rears about 1/12" farther.The factory wheels should be 18" fronts and 19" rears.
Old 11-01-2022, 12:45 AM
Corvette_Dez
Corvette_Dez's Avatar
ESR SR01 Wheels
Here's a great calculator for changing your tire/wheel size.
https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
To Will these wheels fit correctly on my narrow body C6?
Quick Reply: Will these wheels fit correctly on my narrow body C6?
