DIY – Rear Axle / Differential oil change, with pics – for FAQ
#102
One more tip
I really appreciate the detailed photo's and the great write up for this excercise. Thanks for the effort, made it very clear for me. I changed mine a few weeks ago, I choose to leave the car on the ground and it worked out fine.
Not sure if this was mentioned yet or not? One tip, parts stores sell an inexpensive plastic hand pump that attaches directly to the quart oil bottle, it includes a dicharge hose and makes life much easier.
Thanks again
Thanks again
#106
Absolutely great posting... thanks for the info. No noise ever, 11K on 07 C-6. What interval do you recommend a change. This car is perfect. No problems since new.
#107
I had the problem in the winter-changed and no more problems until just the other day when I went up an incline of about 20 degrees at slow speed and the sound was back.. Did a figure eight and there was a rubbing sound and then went away. It is not a good deal, but this post has been excellent. Kudos to the author
#111
I just want to be sure I do this right...what exactly needs to be "level" and what on the car can I measure to be sure it's level? The car has a rake to it so I'm dubious about where exactly I need to check to ensure the car is actually level so the fill plug is at the right spot.
#113
I just did the change and it is A LOT quieter now. However, I do notice at time it feels like I am running over something when I do sharp turns and while doing the figure 8. Is this normal with the new fluid?
#114
anyone actually run the car in 2nd gear at 10 mph for a minute during the fluid change ? seems kind of unsafe to me, just wondering how many of you actually did this step ?
#115
Which is the better product to use now since the test of time has gone by. Amsoil? or the GM fluid? I'm not sure if Amsoil has friction modifier still in it automatically as GM states no friction modifier is needed with their LS fluid.
When is a good time to change the rear diff fluid? (I don't have any chatter or problems with rear diff-this would just be maintenance).
Size of the allen wrench for 2005 drain and fill plugs?
#118
I'm not sure if they released a new version of the LS fluid, but the people that did a change with the Amsoil fluid didn;t have the problem come back.
http://forums.corvetteforum.com/c6-t...gear-lube.html
http://forums.corvetteforum.com/c6-c...oil-or-gm.html
http://forums.corvetteforum.com/c6-c...d-chatter.html
http://forums.corvetteforum.com/c6-t...ial-fluid.html
#119
#120
Location: The Surgeon General has warned that it's ok to smoke mustangs!
1 Post
St. Jude Donor '06-'07
I dont have my Manual on me, but can anyone tell me how often this needs to be done? (i.e., after how many miles, etc....)
Thanks and regards,
BAMF AE
Thanks and regards,
BAMF AE
