07 GM Racing Spoiler Detailed Install Pix
Old 09-09-2006, 06:22 PM
RBYCC
RBYCC's Avatar
Default 07 GM Racing Spoiler Detailed Install Pix
As promised, here are detailed installation pix with comments !!
1) Use torx screwdriver to remove tailights. Leave them hanging, they are not in the way
Photo Sharing - Upload Video - Video Sharing
2) Access existing spoiler mounting studs through tailight opening. Use a 10MM deep socket to remove 4 nuts from studs.
3) Remove four mounting studs and CHMSL from existing spoiler and transfer to new spoiler. Vise grip at base of stud can be used to remove stud.
4) Studs and CHMSL installed in new spoiler
There is a problem at this point that didn't show up until the spoiler was installed.
The center most two studs that hold in the CHMSL install in a more recessed manner then on the stock or Z06 spoiler. This causes the stud not to protrude enough into the body cavity. You can't get the nut on.
Good news is that even without these two securing points the spoiler is on very solid.
5) Cut out the supplied template and tape to the body as per the instructions. Use a Phillips head screwdriver to gently center punch the four holes that must be drilled
6) Drill a pilot hole first on the center points, then enlarge with a 1/4" bit. Body is soft, so low speed and no pressure required on drill. End result as below
7) The center opening for the CHMSL connector MUST be enlarged. Use a utility knife to cut toward the hatch.
8) Install the four supplied tinnerman nuts to the new spoiler. Pull the mask off the VHB tape, and install on the car !!!
[9) The install is the reverse of the removal. Helpful to use a swivel head 1/4" drive ratchet with 10MM socket to tighten the two new outermost nuts.
FINISHED INSTALL
Waiting for the Quantum chin spoiler to arrive and then I'm done?
Old 09-09-2006, 06:29 PM
jcortney
jcortney's Avatar
Outstanding!
Thanks so much for taking the time to document the install.
Two questions. Where did you buy the spoiler and did it come painted?
Also, love the black out tail lights. Where'd they come from.
Old 09-09-2006, 06:31 PM
TicketBait
TicketBait's Avatar
Beautifully done, Great photos and how to
Old 09-09-2006, 06:34 PM
shaan
shaan's Avatar
very very very nice man, great work
Old 09-09-2006, 06:44 PM
The Clevite Kid
Support Corvetteforum!
The Clevite Kid's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Excellent photojournalism.
The manufacturers of the various aftermarket products we buy should take the time and effort to provide similar photo-instructions, or at least post them on their website with a link in the instructions.
Thanx a lot !
Old 09-09-2006, 06:48 PM
corvette05
corvette05's Avatar
NICE JOB...YOU MUST GET THE REAR VALANCE TOO...WILL BE TOO HOT TOO HANDLE!!!
Old 09-09-2006, 06:49 PM
LAPDVET
LAPDVET's Avatar
Bravo..
Old 09-09-2006, 06:51 PM
corvette05
corvette05's Avatar
See My Pictures....new Quantum Rear Diffuser...corvette05
See My Post!!!!
Old 09-09-2006, 07:05 PM
Fastronaut
CF Senior Member Emeritus
Fastronaut's Avatar
You did one heck of a nice job. Thanks for sharing the whole process.
Old 09-09-2006, 07:51 PM
Mr. Wonderful
Mr. Wonderful's Avatar
Location: Slower than a speeding bullet................ Fort Lauderdale, FL
Nice job
Old 09-09-2006, 08:03 PM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Excellent write-up. More importantly, that looks awesome.
Paul
Old 09-09-2006, 08:13 PM
thejerseydevil
thejerseydevil's Avatar
Great job. Looks excellence. You convinced me to get one.
Old 09-09-2006, 09:29 PM
TexJeep
TexJeep's Avatar
Nice job with the DIY. Your car looks great with the spoiler installed. And up to now, I thought I liked the ZO6 piece!
Old 09-09-2006, 10:58 PM
67Roadster
67Roadster's Avatar
Old 09-09-2006, 11:45 PM
su8pack1
su8pack1's Avatar
Looks good.
Old 09-09-2006, 11:48 PM
RBYCC
RBYCC's Avatar
Originally Posted by jcortney
Outstanding!
The spoiler is a GM part from the 2007 GCA catalogue. It is available in Machine Silver, Black, Velocity Yellow and Victory Red, and primer.
The factory finish is excellent.
Forum vendors, Beans and Fichtner can order it, about $300-$310 delivered.
Blackout taillights are molded acrylic overlays from GS Creations in Florida. Many forum members use these as you can remove them and reinstall with just new clear VHB tape. About $110.00 delivered.
JohnnyB51
JohnnyB51's Avatar
Nice job and great documentation!
Looks real good, but I wish the spoilers were a little taller.
To 07 GM Racing Spoiler Detailed Install Pix
Old 09-09-2006, 11:53 PM
RBYCC
RBYCC's Avatar
I was going back and forth with Jayme at Quantum over the rear valance. Only ordered the chin spoiler as I really couldn't get a good feel for the rear valance.
Your pictures are better then anything they show, so I may consider the valance once again.
Old 09-10-2006, 12:24 AM
vettejoel
vettejoel's Avatar
St. Jude Donor '07-'08-'09-'17
Looks great. I would suggest however to place a towel in each taillight opening and let them hang down the outside of the bumper to protect the bumper from scratches from the taillights resting on the bumper
Old 09-10-2006, 09:30 AM
buzltyr
buzltyr's Avatar
It's members like you who make this a great forum. Thanks for taking the time to post it. This will be a great help when I do mine.
Quick Reply: 07 GM Racing Spoiler Detailed Install Pix
