Squeeling brakes----advice
St. Jude Donor '07
My rear brakes are driving me crazy. They squeel every time I stop. Brought car to dealer and they put new pads on and they're still noisy. It's a high pitched noise. What can I do next? Where should I look?
Location: Deerfield, Illinois Turn On, Turn In, Track Out
There is a FAQ about seating the brakes. I did it after I got my new Z51 pads and it worked. You just need a relatively lonely road. I see you're in Waukegan. I used 41 early in the AM. No problem.
Originally Posted by steveo242
Which dealer did you use?
You could switch to ceramic pads... Less dust and squeak as long as you are not tracking the car...
St. Jude Donor '07
My front right brakes squealed from the get go. I changed to eradispeed rotors and ceramic pads. For the first 300 miles, all was nice and quiet. Then all of of sudden, the squeal was back. Must be the front right caliper has an issue.
Originally Posted by jesse12804
floor it,then stop hard!!5 or 6 times should do it.It worked for me 5500 miles ago and all is still well...z51 pads,to boot.
My Z51 was made in January '06, and the brakes squeal.
Originally Posted by greenie99
Try driving at a slow speed with your foot applying a little bit of pressure to the brake pedal, just enough so you know that the brakes have somewhat engaged. Let off the brake and do it again.
Z51 and no squeal for 9500 miles. Then all of a sudden a minor squeal for a few hundred miles and then it went away again. I have no idea why it either came or went...but it was sure a pain when it was there.
