C6 Skip Shift Eliminator
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Now at Southern Car Parts....
Do you hate the 1-4 skip shift installed on the C6 Manual Transmission? This little device will elimate that annoying issue.
This kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your C5 Corvette's 6-speed gearbox. This kit uses genuine Delphi Packard Electric Systems division connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function, if you so desire. This kit is designed for use on both the standard MN6 Corvette's 6-speed gearbox and also the M12 Z06 Corvette's 6-speed gearbox. No permanent modifications are required to install this product.
Takes 5 mins to install and is easily reversable.
Each Kit comes with complete installtion instructions.
NOTE: This kit will prevent the CAGS solenoid from engaging but the "1 to 4" light on the dash will still illuminate when skip shift conditions are met.
Click here to purchase....
http://www.southerncarparts.com/prod...roducts_id=104
__________________
Supporting Vendor
Thanks for the orders guys!
Just dropped them off for shipment this morning.
still have 2 left from this shipment. Additional product will be here Monday of next week.
Originally Posted by Old Chuck
Could you explain the issue involved and why this product is useful?
It is usefull when you are driving in slow traffic, and actually want to go into 2nd when the computer assisted gear selection is telling your tranny to put you into 4th.
Even though it didn't happen very often when I drove, having it happen never was worth the 20 bucks to me big time.
Supporting Vendor
If you do not like the 1-4 skip shift installed on the C6 Manual Transmission? This little device will elimate that annoying issue.
This kit will allow you to disable the Computer Aided Gear Selection (CAGS) feature of your C6 Corvette's 6-speed gearbox. This kit uses genuine Delphi Packard Electric Systems division connectors, plugs and seals to protect your wiring harness and CAGS solenoid to allow you to re-connect the harness for full CAGS function, if you so desire. This kit is designed for use on both the standard MN6 Corvette's 6-speed gearbox and also the M12 Z06 Corvette's 6-speed gearbox. No permanent modifications are required to install this product.
You can also check out our website at www.southerncarparts.com for additional information or give me a call.
Jim
Never mind I just orderd!
Thanks Jim
Thanks Jim
FREE Shipping......
1) Do you need to get under the car at all or is this a no brainer?
2) I have no idea how this is installed - is there any issue with this + the window valet?
Thx!
5th Gear
Canada
Do you offer free shipping to Canada?
Still have some in stock.....free shipping...
Click here to order.
Jim
Jim
Supporting Vendor
Originally Posted by Iceman997
2 questions:
Thx!
Thx!
This has no impact on the window valet.
if you have any other questions just give me a call.
Jim
Supporting Vendor
If you haven't already picked up a set of tail light seals for your C6 yet order those at the same time and I can package them together for you in one shipment
Jim
Picked up my car today and my shift has been skipped several times already in one day. I am no grandmother, but sometimes in traffic it just falls into that category and I don't really want to focus on beating the computer while I am driving. I already bought my eliminator, just need to install it now.
BTW, is there anything to protect the bottom of the car siderails from getting scratched when going over speedbumps or into driveways. How much is a replacement piece? Thanks!
I don't get this. Can someone please clear up my confusion.
I read on this thread that this "shift eliminator" thing makes it so the car doesn't force you into 4th gear when you want to be in 2nd.
My car has a light that flashes at retardedly low rpms telling me to shift to 4th from 1st, it looks like 1-->4 right everyone? The car however does not FORCE you into that gear and you can just ignore the light.
So what's all the fuss about? I would like to get rid of this annoying light that comes on all the time but other than that there is no problem. Is that what this mod does, eliminate the annoying light? or is there more to it?
Thank you!
Thank you!
Originally Posted by nicosuave
...My car has a light that flashes at retardedly low rpms telling me to shift to 4th from 1st, it looks like 1-->4 right everyone? The car however does not FORCE you into that gear and you can just ignore the light. ...
For me its not an issue, as I never shift from 1st at such low speed anyway, and when I do it is in heavy traffic and this feature actually works pretty well for me.
Originally Posted by ZBoater
Actually, it does. While that light is lit you will not be able to shift from 1st to 2nd. It will block 2nd gear and you can only do 4th ( haven't tried 3rd yet).
Ok, so it won't let you shift to 2nd when the light is on, but the light only comes on for a millisecond, and you would hardly ever, if ever, shift from 1st at such low speed and low rpms. Which begs the question...WHY DOES THE CAR WANT YOU TO SHIFT TO 4th at SUCH LOW RPM AND SPEED?! If you do shift to 4th at that speed and rpm, it doesn't do it willingly, the engine hates it, you can tell. The car lurches and creaks and hates it.
Would someone please explain then what is the use of this skip shift eliminator thing. Who would ever shift from 1st during the half millisecond that the 1-->4 light is on, or shift from 1st at 1700 rpm going 5 miles an hour. This just makes no sense. Someone wanna enlighten me?
When I am driving fast I probably (no one in front) I probably shift from 1st to 2nd at around 30-40mph. That sucks down gas like a hoover vacuum. Fun as heck though. 2nd gets me to almost what? 70mph? So 3rd, 4th and 5th are pretty much useless. I usually shift from 2nd to 5th anyway (self induced skip shifter). Gotta obey those speed limits!!!
