Driving a US Corvette in Europe
Old 01-02-2006, 11:07 PM
UncleRobb
UncleRobb's Avatar
Default Driving a US Corvette in Europe
I am currently living in the US and I drive a C5. Since I might go back to Europe (Germany) soon and since I don’t want to be Vette-less I wonder what my options are.
1. I could take my 2001 C5 to Europe and try to register it there. The German inspection is very strict. What would I have to modify to pass? To my understanding, in Germany cars are not allowed to use the same lights for the turn and break signals. Would I need to convert to Euro style tail lights or could I get an exempt and drive the car as it is?
2. I could buy a (new) C6 in the US. Would I be able to get the Euro version with different tail lights, FM radio (different so-called emphasis)? Would the navigation system work in Europe? Would the factory warranty be in effect in Germany? Can I get something as an extended warranty in Germany?
3. Of course buying the car in Germany would be least troublesome but probably also the most expensive option with € 53.836,21 (about US$ 64,600) + tax for the C6 Coupe basic MN6 version. This number is to be compared with US$ 44,900 + tax in the US. Did a forum member buy a C6 in the US and took it to Europe?
Thanks, Robert
Old 01-03-2006, 12:26 AM
silvertc6
silvertc6's Avatar
Robert,
I shipped my 05 to the UK and drove it in Europe over several years. No problems. Must indeed be converted to European specs and this does include changing the tail lights. Not difficult or expensive and was done by Vauxhall (GM in Europe with trained Corvette mechanics). Now I am back in the US,have a C6, and would say that it is somewhat better suited for Europe than the C5, if this makes a difference in your decision.
Good luck!
Old 01-03-2006, 12:31 AM
achilds
achilds's Avatar
Take yours with you, buying a car in Europe is expensive.
Old 01-03-2006, 03:23 AM
gota07
Support Corvetteforum!
gota07's Avatar
Cruise-In VIII Veteran
Drop SteveGermany a PM. He could give you a good idea of the requirements.
Old 01-03-2006, 04:12 AM
Jagcvette
Jagcvette's Avatar
Are you going over as a Fed employee affiliated with the military? If so, you can register your vehicle with the military and not have to worry about the European specs. Actually though, the European specs are not that much different than US and only require relatively minor changes, depending on what country you will register the vehicle in.
Old 01-03-2006, 04:53 AM
Corvette Maniac
Corvette Maniac's Avatar
Yep, Only the rear lights and a side turning signal (front fender) will be required... and I believe the DRL's have to be disabled...
Old 01-03-2006, 05:59 AM
Another Yellow
Another Yellow's Avatar
St. Jude '03-'04-'05-'06
The C6 Navigation works perfectly in Europe. When I went to the 24 Hours of LeMans last year with the C5/C6 Registry, three cars had Navigation. All that was needed was the European Navigation disc. No other changes were necessary. It sure made travel from one city to another a whole lot easier.
One vote for buying a C6 here and shipping it over.
Frank
Old 01-03-2006, 01:23 PM
HighPerformanceLS1
HighPerformanceLS1's Avatar
Can you tell me through what method you shipped it over and how much it cost along with any other expenses in bringing your Vette over?
I've had a similar idea to bring my ride over for a little bahn and Nurburgring running but never knew someone who did.
Thanks!
Old 01-03-2006, 01:33 PM
Another Yellow
I was only the passenger, and at the last minute. I'll ask the driver and get some info for you.
Old 01-03-2006, 01:43 PM
HighPerformanceLS1
Thank you!
Old 01-03-2006, 02:22 PM
own2vettes
own2vettes's Avatar
Just curious how you have managed to drive an 05 over "several" years when it has only been 06 for about 2 1/2 days, even if you take into account time zone differences.
Old 01-03-2006, 02:23 PM
own2vettes
own2vettes's Avatar
I think I've figured it out: You meant to write C5 instead of 05.
Old 01-03-2006, 02:33 PM
silvertc6
silvertc6's Avatar
Indeed I did mean to write C5. Thanks
Old 01-03-2006, 02:34 PM
Steve Germany
Steve Germany's Avatar
I am associated with the Military so I did not have to convert the car to German standards. You can get an international plate but that is only good for a month (allows you to buy a US spec car and drive it in Europe).
I do not think that I would try to convert the car to German standards - you will need headlight washers and most likely new headlights in addition to the side markers.
If something goes wrong with the car there could be a problem getting warranty service as well.
German Corvettes
I put mine in a container but I would just use a roll on roll off ship if I had it to do over again.
Old 01-03-2006, 06:52 PM
2muchhp
2muchhp's Avatar
Default Corvette in Europe
We shipped our Corvettes over last June and also several years before that. I'll be glad to answer any questions if you send me a PM
JM
Old 01-03-2006, 09:06 PM
troy144
troy144's Avatar
Old 01-03-2006, 09:44 PM
UncleRobb
UncleRobb's Avatar
Thanks to all who replied.
Originally Posted by silvertc6
Robert,
Good luck!
Would it be possible to do the conversion in the US, respectively order a Euro model and drive it in the US? I suppose that US officials are less strict with cars than are the countries of the European Union.
No, I don't belong to the US military. I didn't know that in Germany cars are required to have headlight washers. This wasn't the case when I still lived there, i.e. in 2000.
Could I get warranty service in Europe for a C6 that I bought in the US?
To Driving a US Corvette in Europe
Old 01-04-2006, 08:55 AM
888usa
888usa's Avatar
It very easy to get the car converted to euro spec & you don't need to convert the headlamps to have washers on them.
Most people bring them to England & they pass the SVA test to make them legal in europe The German test is a lot more changes than than the UK need pass the car in the Uk & it can be driven legal anywhere in Europe. it will cost about $2000 for everything in the Uk & no the warrranty would be no good in Europe but Sat nav works.
I live in England & own a C6
Old 01-04-2006, 10:10 AM
LTC Z06
Get Some!
LTC Z06's Avatar
Yes you can.
Old 01-04-2006, 10:30 AM
Corvette Maniac
The headlight washers are required with Xenon lights, because when the lens is dirty the light can be diverted all around (or something like that) and could blind oncoming traffic...
You might need to change/alter the unit tho, because you need a "city-light" wich is a small bulb. But maybe there are other options...
Quick Reply: Driving a US Corvette in Europe
