Snap-On phneumatic Car Lift (anyone?)
Old 12-29-2005, 04:40 PM
Bone Daddy
Member: Jr Geezer's Club
Support Corvetteforum!
Bone Daddy's Avatar
Default Snap-On Phneumatic Car Lift (anyone?)
Howdy,
Saw a very cool looking Snap-On phneumatic car lift in someone's photo galley here recently. (Portable Scissor-type on wheels). Didn't appear to lift more than perhaps 3 or 4 feet but enough for my needs. Car in gallery was LMB C6 Coupe.
Wondering if anyone else owns one for maintenance, cleaning, and/or wrenching? Also wondering how stable???
Type? model? I can't find on SnapOn's site.
Thanks,
Reid
Old 12-29-2005, 05:07 PM
Karfever
Karfever's Avatar
Old 12-29-2005, 05:10 PM
gotogolfinvette
gotogolfinvette's Avatar
I saw that also Bone Daddy. My neighbor is a snap on Dealer. I mentioned it to him the other night. He said he could get one for me. If you can't find out any information on here. I will see what I can find out.
Old 12-29-2005, 05:14 PM
bradb
bradb's Avatar
St. Jude Donor '06-'07
Here it is..
http://uucurl.com/x.php?p=1526
I have a few friends around the country who have them and love them. $4000 retail.
Old 12-29-2005, 05:27 PM
Bville-Bud
Bville-Bud's Avatar
St. Jude Donor '05-'06-'07-'08
How about this:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Description:
Services a wide range of cars, light trucks, and vans. Ideal for tire shops, brake and wheel alignment shops, rustproofing operations, transmission shops, and more. Power pack with 12' hose and quick-disconnect are standard. Power pack also doubles as a tow cart to provide convenient flexibility for using the lift in multiple locations.
Low drive over height allows lift to be easily positioned under a disabled vehicle.
MID RISE PLUS SCISSOR LIFT for Tire, Brake and Body work, 6,500 lb. Capcaity, automatic mechanical safeties, twin cylinders, 52 3/4" maximum working height, single piece rollformed deck, 110 V/ 1PH/ 60 Hz.
Features:
- Space-saving scissors lift raises vehicle straight up with no fore or aft movement.
- 48" lift height facilitates bodywork and tire, wheel, or brake service.
- Low 4 7/8" drive over height allows lift to be easily positioned under a disabled vehicle.
- One-piece solid deck accommodates cars, trucks, motorcycles, small engines and many large, odd-shaped parts.
- Adjustable frame contact lifting arms rotate through 360° permit lifting at any factory approved frame lift point.
- Pad style lifting with four standard lift blocks. Optional truck adaptors are available.
- Newer safety features include five-position mechanical safety, foot pedal release of safety locks and twin cylinders with flow control monitoring system.
- Oilite bushings at hinge points for maintenance free operation.
- Power pack doubles as a tow cart to enhance portability.
EELR338AP Mid-Rise Lift (Electric)
Here is a great thread on another site:
http://forums.pelicanparts.com/showt...hreadid=190582
Old 12-29-2005, 06:18 PM
vetteman22
vetteman22's Avatar
I bought a bendPac for my garage.I got the low rise that takes it up about 30 inches for about 1200.00 ......4000 is kinda steep
Old 12-29-2005, 08:41 PM
Bone Daddy
Bone Daddy's Avatar
Default Thanks!
Appreciate the timely feedback guys. Got to admit I wasn't expecting $4 grand worth of lift. I know...... SnapOn makes a good product.
At the moment I'm wondering if that electric "umph" isn't what is driving the cost up that high.
On the other hand doesn't seem like that much steel-hardware in the frame design to drive costs that high.
Wondering if it comes pheumatic only(???)
Yo Vetteman22.....what is a bendpac? Please elaborate.
Old 12-29-2005, 09:42 PM
webdzynes
webdzynes's Avatar
Check this out:
http://cgi.ebay.com/ebaymotors/6000-...00184102QQrdZ1
Old 12-29-2005, 11:57 PM
quickride
quickride's Avatar
I ran across this website last week.
http://www.ezcarlift.com/
Old 12-30-2005, 02:43 AM
vetteman22
vetteman22's Avatar
Bend-Pak's Low Rise Lifts - 6,000 lb. capacity auto lifts
Model LR-60
Low Rise Lift
This is the model that started it all! With it's 6000 lb. capacity combined with durable construction, the LR-60 is Bend-Pak's most popular model. It was specifically designed to increase effieciency and help make your job easier. Whether you choose the bolt-down model LR-60, or the portable model LR-60P, (see below), you can depend on raising profits and productivity.
6,000 pound lifting capacity
Electric/hydraulic power system
Hands-free safety system
Rubber lifting blocks included
Dropped cross bar for added clearance
Heavy-duty steel channel frame
Lifting capacity 6,000 lbs
Lifting Height 26"
Lifting Time 36 Seconds
Lowered Height 4"
Max Lifting Height W/ Blocks 29"
Overall Length 82"
Overall Width 70"
Lift Pad Dimension 18" x 52"
Motor - 110/220 VAC, 60hz, 1ph
Old 12-30-2005, 03:24 AM
ein Tier
ein Tier's Avatar
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
C6FirstVette is the one with the lift (and the LMB Corvette and an Elise).
Old 12-30-2005, 05:43 AM
C6FirstVette
C6FirstVette's Avatar
I think that be me...buying the lift was the BEST purchase I made in a long time (other than getting my Vette ) Use it all the time
I show this pic because some of the lifts have a solid plate where the arms swing out...this will block access for areas directly under the car
Also if you have lowered your C6 (I have...just using the OEM adjusters so it is about 3/4" lower) or a low car to start with (Elise) you will need the boards to allow for clearance over the lift
Michael
Old 12-30-2005, 06:01 AM
Jagcvette
Jagcvette's Avatar
That's a nice looking lift and I'm sure it's good quality. But at 1K lbs., your not going to be moving that sucker around alot!!!
Great pics C6Firstvette!, would love meet up with you sometime next spring when I get back, don't think we live too far apart. Jeff
Old 12-30-2005, 07:03 AM
Sparky65
Sparky65's Avatar
Here's a link to Mohawk Lifts counterpart: http://www.mohawklifts.com/consumer/hr6.php
Mohawk is probably the best lift money can buy, bar none!
Old 12-30-2005, 08:17 AM
Bone Daddy
Bone Daddy's Avatar
Originally Posted by webdzynes
That's about the price I was hoping for but with SnapOn Quality. Hahaha.
I presume this lift is Chinese goods with that price. Kinda scary that there is no brand mentioned. Gotta wonder about replacement parts.
Either way thanks for the info webdzynes.
Reid
Old 12-30-2005, 02:06 PM
Bville-Bud
Bville-Bud's Avatar
It's not a Snap-On, but I have heard good things about Mohawk lifts.
BTW Michael,
I think I have told you this before, but Mr. Blue and the Elise make me drool... VERY NICE!
Old 12-31-2005, 09:04 AM
Bone Daddy
Bone Daddy's Avatar
Default C6firstvette, Bud Gordon and all.......
Thanks C6FIRSTVETTE. This place is great. Hey I appreciate you chiming-in with the great info and pics. You have one sweet garage setup (and two awesome whips) there Bro. I'd be scared to drop or spill something on that clean perfect floor. Kudos!
Did you have to pony-up the $4 Bills for your SnapON or were you able to find a discount somewhere? (Rep, website, etc)
Bud....very informative post esp the link you furnished.
Thanks again
Reid in Houston
To Snap-On phneumatic Car Lift (anyone?)
Old 12-31-2005, 09:14 AM
C6FirstVette
Actually I got a super deal... performance shop had the lift and used less that a year...maybe used 6 times and was in perfect condition...shop even change hydraulic fluid prior to my picking it up...deal was get it out of his shop by weekend (he was replacing with a HD four pole lift the following Monday) and it is mine for $1000... hmmm...let me think Got my son and 5 of his buddies to move...weights about 700 lbs. I would look for a used one...maybe you can run into something like I did
Michael
Old 12-31-2005, 09:15 AM
C6FirstVette
Bud and Jagcvette...thanks and absolutely lets get together after your return...maybe have a few other Vette drivers join us
Take care all
M
Old 12-31-2005, 10:27 AM
Brandegee
Brandegee's Avatar
Does anyone have any experience with Directlift products? This one has a minimum height of 3 7/8" and seems reasonably priced.
http://www.directlift.com/auto_lifts/pro6mr.html
http://www.directlift.com/auto_lifts...6mr_manual.pdf
Quick Reply: Snap-On phneumatic Car Lift (anyone?)
