Competition Mode?
Old 12-28-2005, 10:09 AM
shagsC6
shagsC6's Avatar
Default Competition Mode?
Does anyone actually use this? Why should the Vette even have it???
Just want to add that im a new owner of a c6 this month and haven't really got the chance to enjoy it yet.....Weather...
Old 12-28-2005, 10:28 AM
RBYCC
RBYCC's Avatar
The "competition" mode allows more driver input over the computer, but will keep you out of trouble if you begin to lose control !!!
Old 12-28-2005, 10:32 AM
dstelbrink
dstelbrink's Avatar
If you auto cross your car it lets the driver have a little more controll of the car but doesn't turn traction controll off completely. It will let you take the back end out before the computers start to correct for your errors. With everything turned off you can just to 360's and look like a "drifter".
Old 12-28-2005, 10:35 AM
Gearhead Jim
Support Corvetteforum!
Gearhead Jim's Avatar
Received 2,051 Likes on 1,362 Posts
St. Jude Donor '13
MAY keep you out of trouble if you begin to lose control.
As Dave Hill said, the system works well to help you but it can't overcome the laws of physics.
Use the AH/TC systems on the car like a warning- if they kick in it means you were trying to exceed your traction limits for those conditions.
Maybe that's OK for the particular circumstances, but you should be thinking about what it means.
I use the default "On" for wet roads, "Competition" for fun daily driving or road courses, and "Off" for autocrossing.
Old 12-28-2005, 10:55 AM
haljensen
haljensen's Avatar
Competition mode DOES turn Traction Control off, it modifies the Active Handling settings to allow more driver control.
Old 12-28-2005, 11:17 AM
famous1
famous1's Avatar
I drive in this mode each time I start her. (Two quick depressions of the button.) I go back to default only when I get onto a freeway. When I first got the C6, I was pulling out of a fuel station and there was a little water at the approach to the street. When I pulled out I needed to give it a little gas to get out of the way of a car changing from the number 1 land to the lane I was entering. She fell flat on her face when the traction control shut her down. I didn't like it, so now I drive her all the time on competition mode.
Old 12-28-2005, 11:37 AM
C6-CYa
C6-CYa's Avatar
St. Jude Donor '06-'09-', '22
Drag racing...
Old 12-28-2005, 11:50 AM
Lazerwolfe
Lazerwolfe's Avatar
Location: I am Jack's out-dated Fight Club reference. MD
Why shouldn't it?
Old 12-28-2005, 11:57 AM
NHRA397
NHRA397's Avatar
When I go to competion mode the dash tells me the traction control is back on.
Old 12-28-2005, 12:00 PM
jim213
jim213's Avatar
Old 12-28-2005, 12:08 PM
3 Z06ZR1
3 Z06ZR1's Avatar
Too. much gas 3000 pounds 430 crank hp
Comp mode is a good thing saved many from diaster
Old 12-28-2005, 12:11 PM
calemasters
calemasters's Avatar
From the OM, page 4-11:
Competitive Driving Mode
The driver can select this optional handling mode by
pressing the ACTIVE HANDLING button on the console
two times within a five second time period. A chime
will sound and COMPETITIVE DRIVING MODE will be
displayed in the DIC. Competitive Driving Mode
allows the driver to have full control of the rear wheels
while the Active Handling System helps steer the
vehicle by selective brake application. The instrument
cluster light will not be on. The Traction Control System
will not be operating. Adjust your driving accordingly.
When you press the ACTIVE HANDLING button again,
or turn the ignition to ACC, the Active Handling and
Traction Control Systems will be on. The TRACTION
SYSTEM AND ACTIVE HANDLING-ON message will
be displayed temporarily in the DIC and a chime will
be heard.
Old 12-28-2005, 12:33 PM
Buffy
Buffy's Avatar
Originally Posted by famous1
... She fell flat on her face when the traction control shut her down. I didn't like it, so now I drive her all the time on competition mode.
That's funny - mine doesn't do that, although I'd expected it would. TC will limit the wheelspin, but it doesn't just cut it off. And I can get fairly sideways in "normal" mode. Haven't had much need for competition mode on the street.
Old 12-28-2005, 12:39 PM
blkc6z51
blkc6z51's Avatar
Turn it all off if you autocross, you want to do the driving you will go faster with out it.
To Competition Mode?
Quick Reply: Competition Mode?
