Anyone figured out how to turn off the DRLs?
In the US DRLs are not required. Personally I prefer to be in control of my headlights and decide when I want them on during the daytime.
Has anyone figured out how to shut them off? There is an awesome website that I came across with instructions for all different types of cars but the C6 was not there.
Soon to be C6er...
Soon to be C6er...
Don't think anyone has found a practical way to shut them off permanently. You can shut them off each time after you start the engine by twisting the light stalk to off and release back to AUTO. But you will have to do it every time you start the engine.
Don't forget that they're also the turn signals.
I leave my on the auto setting. No headlights, only the amber running lights, which I think look cool.
Why?? Daytime running lights have been verified as a true safety factor and clearly make the car more visible in daylight to oncoming cars. In fact many insurance companies (USAA for example) give a discount if your car has them. Would you rather look cool or end up in a crash?
I don't like them on either. I don't think the car looks right with them on - they should be down lower where the fog lights are. But nobody seems to have a fix. They are controlled by the BCM. And you can't pull the bulb or wiring because they are the turn signals. That leaves turning them off everytime you get in the car.
BTW, as a note - if you turn just the fog lights on, the DRL's actually dim, and look okay.
Why, you can't see them when they're on?
Soon to be C6er...
Soon to be C6er...
yeah the drl's look ghey i turn them off all the time
sometimes i forget but when i get behind another car and see the reflection i immediately hit them off
The DRLs on the C5s also use the turn signals. You can remove the #2 fuse from the fuse block to disengage them, but, you also loose the reverse backup lights for the "approach lights on" option on the DIC. Don't know if it works the same on the C6. Never had a problem with the DRLs burning up the turn signal bulbs in the C5 though.
