NAV MP3 Static FIX !!!!!!! Finally !
#161
Originally Posted by Minkster
What ISO converter program did you use, or can you just burn to a CD as a "Data" file?
#163
Originally Posted by abrimberry
Right Click Link, Select "Save Target As..."
~10MB Download
Unzip archive
Write the 2 ISO images to 2 CDs
Follow instructions in the text file
If you don't know how to write ISO images to CD, search google.com.
You will need a program that can convert and write an ISO image to CD.
ISO Converter and Burner
Might try extracting files and just writing them to CD:
ISO Extractor
Performed upgrade on VIN 101586 (Sept. 2004). See picture below.
Click thumbnail to view larger image:
~10MB Download
Unzip archive
ISO Extractor
Thanks for the links and info. I love this forum!
You saved me a trip to my dealer.
SB
P.S. Cut and paste "write ISO images to CD" in Google search and the first choice gave me the link to the free software to write the downloaded files to cd's
Thanks again! Vin: 1159xx, Built Feb 05
#164
Originally Posted by Braced
I just followed your post and did the upgrade. It went without a hitch. Now I just have to make some MP3 files and see if it works.
SB
Thanks again!
SB
Thanks again!
#165
Got the 2 CD's burned, now just need to know if anyone has done this to a radio with a different part number than what is in the bulletin.
#166
~10MB Download
Unzip archive
ISO Extractor
~10MB Download
Unzip archive
ISO Extractor
#167
I went for it and did the deed, and it worked, even though the dealer told me the Tech 2 said my radio was the wrong part number!!
Thanks abrimberry, you da MAN!!!!
Did you hold the acces button down long enough for the car to come "ON" vice just access?
Try turning the car back on again holding the access button down for at least 15-20 secs, and if it comes on, restart the process.
Hope it works
Originally Posted by VetteVeteran
Well my Accessories shut down while it was doing disk 2. The unit is now stuck with the screen open and everything off. Think I fried it.
Hope it works
#168
Hope it works
Hope it works
I am so glad this worked out for you Minkster.
#171
I did not hold the ACC down long enough. The disk is in the DVD slot and the stereo is just off with the screen down.
#172
~10MB Download
Unzip archive
ISO Extractor
~10MB Download
Unzip archive
ISO Extractor
Thank You! Thank You! Thank You! I just downloaded the disc's and did the update. Fantastic! Works just great, MP3's here I come, no need for the 6 disc changer and one saved trip to the dealer . Doesn't get much better than that except, maybe Summer
#173
St. Jude Donor '05-'06-'07-'08
http://www.magiciso.com/
You can't burn the ISO file directly to CD and it work. You might be able to find an ISO extractor and then write those files directly to CD, just haven't tried it with these CDs. Thanks.
Searched Google with "iso extractor", found link below. Trial version extracted the files. ISO Extractor
Just Did mine also..I Thought it got mess up because when i Turn on the Car And Put The NAV DVD back in it The LAst Step..Gave me a Error.(Wrong MAP CD) something like that...Took it out like 3 times and same thing...i was like oh Shat!..So i turn the Car off and turned it back on and presto it was working....Now all i nned to do is make a Mp3 Disk and Try it out...Thanks...
#174
Added link to an archive that contains the individual files that can written directly to CD. This is a work around if you don't know how to work with ISO images. Thanks.
#177
Originally Posted by LMBlewVett
Once the 2nd disk goes in, the screen will go blank for "5 to 10 minutes"....be patient grasshopper.......normal operation.
#178
Originally Posted by YellowVette22
Get your self Limewire...And download MP3's Then burn a cd with the MP3's
I have plenty of MP3s on my hard drive from limewire. But do I just copy a few of these to a disk?
Tried that and it didn't work.
