Michelin PS2s
Michelin PS2s
In case anyone's interested, Michelin is finally making the PS2 rears for the C6 (285/35-19). A Michelin rep I spoke to today said they just began getting them out within the last couple of weeks. I remember some threads a while back where members were commenting that Michelin was not making them yet. Just thought I'd pass it on.
Originally Posted by cleo
Glad to hear it.
Originally Posted by burtonbl103
Nope
thats what make them great !
Originally Posted by Low12s
ummmmmmm. so what are you going to do when you get a flat?
Call AAA, the spouse, or plug the tire, same as a motorcycle etc.
If you are not willing to take the risk for the better tracktion just keep the old tires, no biggie.
Nope
OK, so you put non run flats on your car. I won't even get into the fact that you don't have some increased protection against a flat tire.
My main point is that with a run flat tire, it is less likely that IF you do have a flat, that the tire will go down to the rim. The C5 owner I mentioned had a blow out on the highway and the non run flat tire started coming apart in chunks. Some of the tire severely damaged the front fender well and fender. His aftermarket wheel was also chewed up as a result of the failed tire. It cost $1400 to repair the damage and now his paint doesn't match. He had to spend extra cash to replace the wheel also.
Have you seen the Car&Driver tire test from this month's issue?
The PS2 finished 4th overall. 1st was the Goodyear F1-GSD3
http://www.caranddriver.com/article....ticle_id=10252
I've been run-flat-free for 4 years now on my C5 - and pretty happy I went that way.
Let me go on record as saying that I don't relish the thought of having to spend $1400 -1600.00 for new run flat tires but at the same time I don't want to have to deal with the possible consequences the way the C5 guy had to.
and are within towing distance. and there is a replacement tire near, and that time is not important, etc etc
Discount Tire here in San Antonio for all four tires in stock sizes......
$1,376 total for Goodyear Supercar EMTs mounted, balanced, tax, etc.
$1,347 total for the Michelin PS2s mounted, balanced, tax, etc.
I read the Car and Driver test too but that test took alot of wet weather driving into account which I will do little or none of. It was also done in a different car with different sizes. I like what I see as far as other comments/reviews go with the Michelins. See the Tire Rack reviews and you'll see what I mean.
Decisions decisions.....
