I'm joining the dead battery club
I thought I was not going to be a member but not so lucky. I always shut the car down according to procedure. Transmission in reverse, parking brake on and make sure i get no error messages. I also manually (with the remote) lock the car by pressing the lock button twice and hearing the horn on the second press. I then look in the car to make sure there are no lights on the start switch and that the red pulsing light on the radio panel is flashing. I have left the vehicle for up to two weeks and it always started right up. I drove in Sunday to church and walked by it yesterday to make sure all is right .... I was not going to get caught in the dead battery thing. WELL this morning ( two days after i last drove it) I go out at 5 in the AM to take it to work COMPLETELY DEAD !!
Using the emergency key I get in and hook up a battery charger I at once get to error messages " FOB not recognized" followed by "service control column lock" or such. I take the pick-up to teach and on the way home stop at the dealer. He tells me that they have had several in with those error messages and they will have a truck come pick it up. I'm not a happy camper. I will keep the board informed.
Received 4,551 Likes
2016 C2 of Year
2015 C3 of Year Finalist
Those messages are the result of the dead battery. If you put the car on a charger for about an hour or 2 the car should start. Then take it for a good drive. Did you manually lock the steering column after shutdown? One engineer at Carlisle felt this could be related. This is among many theories such as Relay 46 and external influences. The dealer is a waste of time. They'll most likely tell you everything checks out fine. Good luck.
I can't honestly say that i locked the steering column per say but my shut down procedure is the same every time as I was focused on not being a member of the "dead battery club" I agree that it may be a mission in frustration with the dealer. I have a charger on it right now and will report back
Welcome new DBS club member. Thanks for reporting the details. I'm confident that one day someone will stumble onto something that leads to the answer. So far I'm only a one time member of the DBS club, but until we/someone figures out how to fix the problem, my advice is to invest 60 bucks on a PriorityStart module. Your car may turn up "dead" but at least the battery won't be, and a simple push of the cigarette lighter will start her right up again without any charging needed. One other benefit to the PriorityStart is that it shuts off power at 11.9 volts, avoiding all the random/freakish problems that can occur when the battery voltage drops off slowly and does strange things to the electical system when it gets down under 10 volts. At least the quick shutoff prevents that.
P.S. Have you pulled relay 46?
Mike
Mike
One beneficial thing everyone could do that has the DBS is to list how they have the car programmed. Do you have passive locking on, etc. Maybe someone will be able to recognize a pattern that one of the program options could be a culprit. I'm not saying that all cars programmed a certain way would have the problem, but some could.
Originally Posted by Check 6
I did put a charger on for at least an hour and the car started. I drove at hiway speeds for about 10 miles and put it back in the garage. I will check it tomorrow and the dealer has asked me to bring it in to check the electrical system. Interesting when the battery goes dead the window index memory is lost but not the radio station memories. My car is stored in a dry building, our South Texas climate has been very dry and it has never been in the rain so contact corrision is almost ruled out, but something is putting a drain on a small shallow cell battery. Also interesting that the system is being changed on the '06 so the engineers appear to recognize a problem even if small. Still very happy with the vette.
And do remember to make the sure that the steering wheel locks in place before exiting the vehicle.
I have read this before and have wondered how you Manually lock the steering column. When I shut mine down I put it in reverse, set the emergency brake, and push the off button. What am I missing. In 4200 miles and 5 months I have not had the DBS. Thanks for the information.
[QUOTE=capevettes] Did you manually lock the steering column after shutdown? One engineer at Carlisle felt this could be related.
I have read this before and wondering how you lock the steering column manually. When I shut down my C6 I put it in reverse, set the hand brake and push the button to shut off the engine. What am I missing? I know the steering wheel lock's but not manually.
Joe
[QUOTE=VET4LES]
You need to rotate the steering wheel a tad after turning the car off, and you'll feel it lock in!
After having my battery replaced last October, I have not had this problem since.
Mike
Mike
Originally Posted by c2c4c6
What is a "PriorityStart module" and where do you get it? What is involved in installing it?
Mike
Although I've an automatic and they don't seem prone to DBS, I'm still suspect of that small battery in a car with so much electrical drainage even when functioning normally. Is there a recommended replacement battery that is maybe gell cell technology or more of a deep cycle type batter? I've seen a couple of people use Optima - is that the recommended high amp/high capacity replacement. Thanks.
St. Jude Donor '09-'11
I am a member of the DBS club too (MN6). Had it happen once a few months ago. Jump started and never another problem. I don't lock the steering column. No one has the answer to this problem yet!!
Did you happen to notice if the lights on the bottom of the mirror were on after shut off? We accidently pushed the dimmer on the left side of the dash,causing them to remain on. If it hadn't been dark outside we wouldn't have noticed and probably been a member of this DB club. Just a thought
1 Post
St. Jude Donor '08
Here's sonething odd to add, I have had a dead battery 2 times, and both times were when I left the top off the car???? I was in reverse with all of the lights off both times. My car is a weekend driver, so I leave it in the garage all week, but the only time I had a problem was with the top off. Is this just luck of the draw, or have I entered the twilight zone!!!
