How do you reset the Check Engine Light??
Old 08-18-2005, 09:04 PM
DJackman
DJackman's Avatar
Default How do you reset the Check Engine Light??
Hey Guys, I've heard stories about Check Engine Lights in this forum. Not that I've experience any Check Engine Lights, but I need to know how to reset it in case it happens so Im prepared. Thanks in advance.
Old 08-18-2005, 09:34 PM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,276 Likes on 935 Posts
Owner's manual, pages 3-42 - 3-43.
If the Light Is Flashing
The following may prevent more serious damage to
your vehicle:
• Reducing vehicle speed
• Avoiding hard accelerations
• Avoiding steep uphill grades
If the light stops flashing and remains on steady, see “If
the Light Is On Steady” following.
If the light continues to flash, when it is safe to do so,
stop the vehicle. Find a safe place to park your vehicle.
Turn the engine off, wait at least 10 seconds and
restart the engine. If the light remains on steady, see “If
the Light Is On Steady” following. If the light is still
flashing, follow the previous steps, and see your dealer
for service as soon as possible.
If the Light Is On Steady
You also may be able to correct the emission system
malfunction by considering the following:
Did you recently put fuel into your vehicle?
If so, reinstall the fuel cap, making sure to fully install
the cap. See Filling Your Tank on page 5-7. The
diagnostic system can determine if the fuel cap has
been left off or improperly installed. A loose or missing
fuel cap will allow fuel to evaporate into the atmosphere.
A few driving trips with the cap properly installed
should turn the light off.
Did you just drive through a deep puddle of water?
If so, your electrical system may be wet. The condition
will usually be corrected when the electrical system
dries out. A few driving trips should turn the light off.
3-42
Have you recently changed brands of fuel?
If so, be sure to fuel your vehicle with quality fuel. See
Gasoline Octane on page 5-5. Poor fuel quality will
cause your engine not to run as efficiently as designed.
You may notice this as stalling after start-up, stalling
when you put the vehicle into gear, misfiring, hesitation
on acceleration, or stumbling on acceleration. (These
conditions may go away once the engine is warmed up.)
This will be detected by the system and cause the
light to turn on.
If you experience one or more of these conditions,
change the fuel brand you use. It will require at least
one full tank of the proper fuel to turn the light off.
If none of the above steps have made the light turn
off, your dealer can check the vehicle. Your dealer
has the proper test equipment and diagnostic tools to
fix any mechanical or electrical problems that may
have developed.
The following 2 users liked this post by Vette_DD:
dwhampto (08-04-2017), mickey@cmwvacs.com (04-28-2017)
Old 08-18-2005, 09:53 PM
Michrider
Michrider's Avatar
Two ways. Fix the problem that caused the light. The light will go out after several drive cycles without the problem present. The system will save the code in history and then erase it after many more drive cycles.
The other way is with a diagnostic scanner. Dealers use a Tech II.
If you have Onstar, they can often tell you what has caused the check engine light. The most commone one is leaving the gas cap loose. Tighten it , drive it for a couple days, it'll go out.
That's C6.
Now on a C5 you have the ease of reading and clearing codes using the dash DIC. LAN communications on the C6 put an end to that, great progress.
Old 08-18-2005, 10:23 PM
mike1952
mike1952's Avatar
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
black tape!
sorry, it was just too easy!
Old 08-18-2005, 11:50 PM
0vetteshop
Former Vendor
vetteshop's Avatar
St. Jude Donor '13
That's C6.
Old 04-28-2017, 02:01 PM
mickey@cmwvacs.com
mickey@cmwvacs.com's Avatar
Default Reset Engine Light
your vehicle:
3-42
light to turn on.
have developed.
I have been having problems with my fuel gauge jumping to empty when the tank was still 1/2 full. I have been using tech-tron fuel treatment that was recommended here and am on the 3rd treatment trying to cure the fuel gauge issue,
Yesterday the service engine light came on and it appears the treatment I'm doing with the tech-tron could be causing this.
Any suggestions would be greatly appreciated.
Old 04-28-2017, 05:50 PM
SouthBaySurfer
SouthBaySurfer's Avatar
If it stays on steadily(not flashing), it's an emission problem. AutoZone or O'Reillys will Read the codes and give you a readout of the most likely causes- free of charge. To shut the light off, disconnect negative battery terminal for a minute or so; light will come on if problem still exists. After reconnecting battery terminal, remember to re-index the Windows.
Old 04-29-2017, 08:56 AM
C6ToGo
C6ToGo's Avatar
Received 1,116 Likes on 693 Posts
1) start a new thread instead of replying to a 12-year old one.
2) don't overuse Techron...not good. I think you are supposed to drive a few thousand miles between bottles.
3) It is easier to spend 12 bucks on a simple code reader instead of gong to a parts store. Don't just clear the code, see what it is and research it.
4) the fuel sender contact can get a sulphur buildup that can cause them to stop sending a signal. Techron some times cleans and fixes the problem. Some times not....the little contact arm on the sender also breaks.
5) many threads on "service fuel system" . Search and maybe you will find an answer. Good luck.
Old 08-04-2017, 12:14 PM
dwhampto
1st Gear
dwhampto's Avatar
Thanx! Just bought this used 'Vette. Still under warranty from dealer. Gonna take it back, let them hook it up to diagnostics, then we'll see. Dealer says it'll be OK to drive it that far (110 miles, one way). I've tried the gas cap fix; to no avail. "Check engine" light remains "on", steady.
your vehicle:
3-42
light to turn on.
have developed.
To How do you reset the Check Engine Light??
Quick Reply: How do you reset the Check Engine Light??
