Z51 or just perf. axle?
i am going to order a machine silver vert with an auto trans next week.
i don't know if i should order the z51 or just the performance axle. any
comments would be appreciated
3.15 is great
As always, it depends upon you. I am an older guy who wanted some fun and comfort. The standard suspension with the 3.15 rear end is what I have, and I love it. Comfort with a punch. My DD is a Lexus LS400, so I didn't want to feel uncomfortable in the Vette.
Remember though, you give up a little 'bling' without the drilled rotors. If you want to compromise between the two, add the '51' anti sway bars amd just get the 3.15.
Also, if you want some 'bling', purchase the stock wheels and then trade them in for chrome. You will save a bunch of money. And, while they are putting on your wheels, have them paint the rotors so that the rust issue is put to rest. I had that done at Corvettes of Houston -- only $80 to paint the rotors (silver) since the wheels were already off of the car.
Enjoy !!!
Enjoy !!!
How are the roads where you'll be driving? If they're pretty good, the difference in ride between the base suspension and the Z51 suspension probably won't be much. However, if your roads are pretty crappy, you'll probably be better off with the base suspension and the 3.15 performance axle.
Originally Posted by ASZ2222
Definately get the Z51. I love the ride and handling of the Z51. I wouldn't get the car without it. You get a lot of bang for your buck.
Z51
AL
It all depends on how you intend to drive your Corvette. If you want a little more punch off the line then the 3:15 will give you what you are looking for. For daily driving and cruising the 2:73 will work just fine and give you a little better fuel ecomony to boot.
As for the Z51, it is again a matter of how you intend to dirve or use the Corvette. The base suspension is great and will serve 95% of owners well because their cars will never be flogged around a track or driven to the limit on the street. How many owners heat the brakes red hot or need oil or steering coolers? Sure the Z51 package is a good deal but, if you don't need the stuff, is it really a bargain? I know that a lot of the guys will tell you that it is a must have but, the fact is that it simply isn't. Again, the better ride and great handling of the base system will be all that you will ever need and then some for daily use, cruising, and especially a long trip.
don't forget that the z51 comes with:
the gearing, upgraded suspension, cross drilled rotors, extra coolers for oil PS and tranny.
Z51 isnt just about suspension any longer like it used to be. well worth the $$ in my opinion
1st Gear
Z51
I have had my C6 Vert for 6 weeks or so now. The Z51 option was actually a pleasant surprise. I was expecting a much harsher ride, but it's actually quite comfortable and capable. My former ride was a 1997 911 cab. Naturally the z51 option has lots of goodies besides the suspension--I highly recommend.
Best advice I have seen. It's way too easy to spend other peoples money. Do you feel "drawn" to the Z51? If so, get it. If not, why spend the extra $1300 (over the perfomance gear).
If you do get the Z-51 package you will automatically get the 3.15 gears included
On the automatic Z-51 the 3.15 gears are part of the package hence you won't have to pay for that option if you get the Z-51. But regardless why pay for extra stuff you will never use???
If you just bought the 3.15 gears that is alot less than the Z-51 package that comes with sqeaky brakes, lots of brake dust problems, extra suspension adjustments and short tire tred life.
I have an automatic with the 3.15 rear axle only and I love the ride and handling. The car will take sharp turns at 40mph without even a squeel. The two points that made me turn away from the Z-51 was the stiffer ride (the base suspension is stiff enough for me) and the fact that some of the cross drilled rotors are starting to show signs of cracking. Add to that the brake noise that may occur and a lot of people here on the board saying the tires wear quickly would point me to the base unless you plan on tracking the car on a regular basis....
You can't really go wrong with any option. What I chose was the F55 suspension so I can select between a cushy or stiffer ride. I got the 3.15 axle, A4 auto. I am adding the Z51 sway bars and the cross-drilled rotors. This is a more expensive way to go, but I got exactly what I want. As always, it's a matter of personal choice. Go with what feels right for you.
Z 51 is worth every penny to those who want/need it it. I got the base because I didn't need it. I absolutely love the ride and handling of the base. Replacing tires in 6 to 10 thousand miles is totally not acceptable , at least to me. Many here will tell you it is not a Corvette unless you have a mn6 with the Z51--I would not be one of them.
Former Vendor
Z51 Performance Package Corvettes get a special tire known as the Goodyear Eagle F1 Supercar EMT. Its asymmetrical tread provides higher overall performance and grip in dry conditions
what was the deal with the tires ... are they different also ??
Originally Posted by LS WON
extra suspension adjustments ...
tires
My 2001 C5 has Z51.............The ride is fine & handling is great >>>I am an old fart (57) so probably more critical than the average guy ride wise, also own a 1966 B/B & think she rides OK also. .cost wise when you subtract the price of perf axel from Z51 package ..the Z51 is a good $$$ deal.,A C6 Convertable is in my future & will be equiped with the Z51 .words of wisdom from the old dog
