Driving Terms
Driving Terms
I saw these driving terms and wondered what they are, how you do them and if it's ok to do them in the c6. Thanks for any help...
popping the clutch
power shifts and burnouts
Thanks...
popping the clutch
Thanks...
St. Jude Donor '05
Popping the clutch = just that, letting go of the clutch as fast as possible and stepping on the gas.
Burnout = the result of the above, having the tires spin and smoking them.
Power shift = stepping on the gas and not letting off of the gas as you shift it fast. Some people step on the clutch others rip it into gear without using the clutch, but always have the gas depressed.
Hope that sums it up about right.
St. Jude Donor '05
Oh yeah, I wouldn't recommend doing it with such a beautiful car, but it is yours to do it with. Tires will wear out fast as will the clutch if you do these often.
And then there is "side stepping" where you let you clutch foot slip off the clutch pedal to the right and the clutch pops up all by itself. With judicious amounts of throttle, this also results in smoking burnouts.
Location: Austin, Texas Codes 660, 9448, and 295660 work in the C6 navigation unit. No DVD playback yet.
Burnouts won't hurt much more than your rear tires, and even popping the clutch won't hurt anything unless you do it a lot.
Powershifting though, if it's not done exactly right, will destroy your synchros, which while it won't make your transmission fail, will make it difficult to use.
As long as we're on the subject..
Exactly what is heel/toe and how is the best way for one to learn it properly? I doubt if it is necessary just for street driving, probably just track, right? Can't wait to have my first manual shift since high school, some 37 yrs ago.
*24 and counting
*24 and counting
Location: Heaven, for the climate; Hell, for the company
1 Post
Thought "power-shifting" was skipping intermediate gear(s), going from 1st to 3rd or 2nd 4th, etc. (Sort of what CAGS does now, but with power). Also used to "double clutch" old transmissions, when down shifting and braking at same time, to avoid lurching, to get engine and tranny revs to match. Not sure if it had any practical value, but the girls always seemed to be impressed.
1 Post
Originally Posted by WWK888
Uhhhh....nope. See C6 Girl's post for correct defination of power shifting.
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
*24 and counting
*24 and counting
"popping the clutch" is when you have a car that's off and you get it rolling then with the car in first engage the clutch briefly to use the cars momentum to turn over the engine. If done right you can start a car with a dead battery this way, but it's rough on the clutch.
Originally Posted by Datawiz
Heel/toe is a form of braking and driving with the same foot. Many race car drivers do this. Basically, they use their right heel on the brake and thier right toe on the throttle so they can get a mixture of both with the same foot. I've tried it, but I'm just too damn tall to do it. My right leg is already out of position.
down shifting
*24 and counting
*24 and counting
When under HARD braking and one has to downshift to the next gear. the left side of the right foot is pushing hard on the brake, the right side of the foot, accentuated by an ankle roll 'blips the accelorator' or revs the motor to increase the RPMS, thus allowing the downshifting of the transmission, syncros and the engine rpms to match.
This takes a lot os skill.
After reading this, possibly some of you can help me with a Texas driving term my wife uses? She often looks at me and says: "I know your engine's runnin' but ain't nobody driving". I am not sure what she means.
Location: Buena Park, CA I seem to have left my electrolytes with your daughter
Originally Posted by AU N EGL
Terms:
Apex
Late apex
Track out
feather
Trailbrake
Trailbrake throttle oversteer
Apex
Late apex
Track out
feather
Trailbrake
Apex is just that, the Apex of a turn. Picture the "point" in a 90 deg corner at a stop light, or the "highest" part of a semi-circular curve.
A double apex is two alternating apecis read: "S" curve
Tracking out is the use of the entire course. It allows you to essentially broaden a turn, so that you can take it at higher speed. When making the turn approach the apex on the inside in a smot straight manner, then as you go through the turn (lower throttle) hold onto the apex, then throttle up and move to the outside of the straightaway or the inside of the next apex in a double apex turn. When you're doing this you are hugging the outer edges of the track/course at entry and exit of the turn, hence using the entire track. This is a very effective....and fun... driving technique that I do when the streets are empty at 3:30 in the morning!!
CI-7-8-9-10 Veteran
The term 'heel& toe" is not discriptive. One does not put the heel on one peddle and the toe on an other.
Originally Posted by GGWOODY
I know a couple:
Track out is after you pass the apex of a corner then you roll the throttle to the flow and alow the car to accerlorate as the car moves to the opposit side of the road.
Double apex is a result a long, long sweeping corner with a few short straights. the whole corner is in one direction and holding your steering wheel in one place will not work.
Here is some very good information on cornering
http://www.nccbmwcca.org/drivers-sch...e-driving.html
1 Post
