Corvette Forum
Go Back   Corvette Forum > C6 Corvette, 2005 - 2013 > C6 Corvette General Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
General C6 Corvette Discussion not covered in Tech Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Closed Thread
Old 03-19-2005, 12:28 AM   #1
mrdork
CF Member
mrdork's Avatar
Default Fill up & get the "Check Engine Light"?
Over 4700 miles on my C6 without any real trouble. However, after filling my tank this evening, I received the "Check Engine" light along with the message "Service Fuel System" on the DIC. "Ok, I guess I didn't properly tighten the gas cap..." so I checked - it was tight. I removed it and re-tightened. Same error message. During the short 8 mile drive home, the DIC alternated between "Service Fuel System" and proper operation and the fuel gauge alternated between full and empty (in sync with the DIC.) Once home I shut down, inspected the gas cap & filler neck but could find nothing wrong.
Since I haven't purchased a scan tool yet I can't check the error code tonight. I guess I'll have to take it to the dealer in the morning
Has anyone else experienced this behavior?
mrdork is offline
Old 03-19-2005, 12:31 AM   #2
JJayzX
CF Senior Member
JJayzX's Avatar
Send a message via AIM to JJayzX
Do you think the sensor that tells if gas cap on or off could be faulty.
JJayzX is offline
Old 03-19-2005, 12:41 AM   #3
AveryOBX
CF Member
AveryOBX's Avatar
Did you leave the engine running while you were filling up? Yea I know, stupid question but this is the most common cause.
AveryOBX is offline
Old 03-19-2005, 01:26 AM   #4
Braced
CF Senior Member
Braced's Avatar
Default OnStar
If your car is equiped with OnStar, they can tell you the code and meaning of it. It's one of the selling points of OnStar for me.
Braced is offline
Old 03-19-2005, 10:20 AM   #5
need1
Junior Member
need1's Avatar
not quite the same problem but my check engine light came on and the cap was tight.....turned out to be the oxegon sensor - dealer replaced it and all is fine.
need1 is offline
Old 03-19-2005, 11:34 AM   #6
mrdork
CF Member
mrdork's Avatar
AveryOBX - No, C6 was off during fueling.
Braced - No OnStar.
need1 - Interesting.
We'll see what the dealer has to say later today...
Thanks for the input!
mrdork is offline
Old 03-19-2005, 12:36 PM   #7
carpe dm
CF Senior Member
carpe dm's Avatar
Did you over-fill and get some gas in the return pipe? That would do it.
carpe dm is online now
Old 03-19-2005, 04:50 PM   #8
DP Dave
CF Senior Member
DP Dave's Avatar
800 miles and my DIC read "Service Fuel System", fuel gauge went to empty. Turned out it was the Fuel Gauge Sending Unit.
DP Dave is offline
Old 03-19-2005, 07:05 PM   #9
digbyamb
CF Senior Member
Support Corvetteforum!
digbyamb's Avatar
This is well documented within the forum. I had this exact same thing happen at 250mi and it was a FSU. The dealer needs to replace it, make sure his has one in stock BEFORE he removes the tank or you will be sitting without your car for up to a week.
digbyamb is offline
Old 03-19-2005, 10:40 PM   #10
Dash Culpepper
CF Senior Member
Dash Culpepper's Avatar
I have the same problem. My dealer had to order a left sending unit. I am still waiting for it to come in. Including yours and mine that makes at least four C6's that have had the same problem. This was a problem that was not uncommon in the C5
Dash Culpepper is offline
Old 03-20-2005, 01:28 AM   #11
mrdork
CF Member
mrdork's Avatar
Default Wow, the C6 can self-heal!
Went to the dealer this morning but their service dept. was closed. So, I continued with my day running errands. After about 35 miles and the fourth start, the check engine light no longer illuminated and has not returned.
Yes, it is possible that I overfilled the tank since I always give the pump an extra shot to make sure it's really full (not a crappy pump shutting off early.)
I'll go to my regular dealer (near my office) on Monday and have them check to codes to find out what really happend.
Thanks to everyone for your quick suggestions and pointers!
Best regards,
-Mark-
mrdork is offline
Old 03-20-2005, 02:17 AM   #12
LS WON
CF Senior Member
LS WON's Avatar
Default I have been topping of to the point where the fuel will spill out of the cap.
Best regards,
-Mark-
I find that I can usually get one more gallon in after the click.
LS WON is offline
Old 03-20-2005, 03:47 AM   #13
champ_85
CF Member
Send a message via AIM to champ_85
Quote:
Mine happened at 1300 miles. I took my car back to the dealer and didn't see if for a week Wish I had seen your warning earlier!
champ_85 is offline
Old 03-20-2005, 06:24 AM   #14
digbyamb
CF Senior Member
digbyamb's Avatar
Best regards,
-Mark-
I think you will find that as soon as you fill your car the problem will be back until you burn some of the gas off (I found that if the tank was 1/2 full or less the problem disappeared).
Don't let the dealer remove the tank without having the FSU in stock. He can check it using the codes without tank removal. I waited 7 days with the tank sitting on the floor of the shop waiting for a FSU to arrive.
digbyamb is offline
Old 03-21-2005, 12:51 PM   #15
Dash Culpepper
CF Senior Member
Yep, I am still waiting for the part to come in, it has been two weeks now. I called GM this morning trying to see what I could do to get this matter moving and really did not get any where. My '03 was bought back by GM under the Lemon Law, I sure hope this is not going to turn out the same way again. I did not think lightning could strike twice.
Old 02-14-2011, 08:14 PM   #16
billdog
Junior Member
Was this covered under warranty? I have the same problem, but my 3 year 36K warranty expired in November 2010. I think it might be covered because the check engine light is on.
billdog is offline
Old 03-09-2012, 08:59 PM   #17
soemer
Junior Member
Default Check engine light comes on in my 2000 Corvette after fuel level reaches 1/2
My problem is just the opposite. My check engine light comes on just about the time I reach the 1/2 full point and below. It goes out after a few miles after I fill up. The code says evap. emmisions.
This never happened until I had the fuel level sending unit(s) replaced. I have a 2000 Corvette, and they had a problem with the gas guage reading empty as soon as it hit 1/2 tank. ABout six months after the sending units were replaced, the problem began, and I have now had it for years.
I'm guessing an air leak somewhere, but I have no idea where to start looking. Any thoughts?
soemer is offline
Old 03-09-2012, 10:44 PM   #18
Knob Jockey
CF Senior Member
St. Jude Donor '11-'12-'13
Knob Jockey's Avatar
You guys should consider starting a new thread, this one is ancient.
Sorry for your problems, nonetheless.
Knob Jockey is offline
Old 03-09-2012, 10:55 PM   #19
MikeyTX
CF Senior Member
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
MikeyTX's Avatar
Default Forum Rules .............
Existing threads receiving no replies for 45 days or more.
If an existing thread has not received a reply for a period of 45 days or more, members should create a new thread which is identical or similar in nature, rather than to post to the existing one.
MikeyTX is offline
Old 03-09-2012, 11:48 PM   #20
johnodrake
Moderator
johnodrake's Avatar
Johnodrake @CdrDrake johnodrake
Indeed
johnodrake is online now
Reload this Page Fill up & get the "Check Engine Light"?
Closed Thread
Tags
02, 1982, 2005, c6, check, code, corvette, diagnosis, empty, engine, filled, filling, gass, guage, light
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
