Sah - b0161
Sah - b0161
Had the Service Active Handling come up.. went and had the code read. They told me it was B0161. I did a search here and come up with nothing. Anyone have any info?
Service Information
2006 Chevrolet Corvette | Corvette VIN Y Service Manual | Brakes | Antilock Brake System | Diagnostic Information and Procedures | Document ID: 1460376
DTC C0161
Circuit Description
The brake pedal position (BPP) sensor is an input to the body control module (BCM). The BPP sensor is a potentiometer type sensor with a 5-volt reference circuit and a low reference circuit. The BCM supplies the 5-volt reference to the BPP.
DTC Descriptor
This diagnostic procedure supports the following DTC:
DTC C0161 ABS/TCS Brake Switch Circuit
DTC Symptom
DTC Symptom Descriptor
11
Above Maximum Threshold
12
Below Minimum Threshold
Conditions for Running the DTC
C0161 11
The ignition is ON.
The vehicle speed is greater than 16 km/h (10 mph).
The ignition voltage is greater than 8 volts.
C0161 12
The ignition is ON.
Conditions for Setting the DTC
C0161 11
The brake pedal is sensed as applied.
The vehicle speed is greater than 40 km/h (25 mph).
The vehicles acceleration exceeds 8 km/h per second (5 mph per second).
C0161 12
Brake pedal is not applied.
Master cylinder pressure is greater than 150 psi.
The vehicle speed is greater than 24 km/h (14 mph).
The vehicles deceleration exceeds 11.5 km/h per second (7 mph per second).
Action Taken When the DTC Sets
If equipped, the following actions occur:
The EBCM disables the engine drag control (EDC)/tire pressure monitor (TPM)/vehicle stability enhancement system (VSES) for the duration of the ignition cycle.
The Traction Control System (TCS) is degraded.
The Traction Control and Active Handling indicator turns ON.
The driver information center (DIC) displays the following messages:
Service Traction System
The ABS remains functional.
Conditions for Clearing the DTC
The condition for the DTC is no longer present and the DTC is cleared with a scan tool.
The EBCM automatically clears the history DTC when a current DTC is not detected in 100 consecutive drive cycles.
Diagnostic Aids
C0161 11
Possible causes of this DTC are the following conditions:
The BPP sensor circuit is shorted to voltage.
The BPP sensor needs recalibration.
A brake pedal that is binding
C0161 12
A signal circuit of the BPP sensor is open.
All brake lamps are open.
All brake lamp grounds are open.
An internal BPP sensor malfunction
Test Description
The number below refers to the step number on the diagnostic table.
2 Test for the current state of the brake pedal position sensor.
Step
Action
Yes
No
Schematic Reference: Antilock Brake System Schematics
1
Did you perform the Diagnostic System Check – Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle
2
1.
Install a scan tool.
2.
Turn ON the ignition, with the engine OFF.
3.
With a scan tool, observe the brake pedal position sensor (BPP) Reference Signal parameter.
Does the scan tool display Released?
Go to Step 3
Go to Step 4
3
1.
Press the brake pedal.
2.
With a scan tool, observe the BPP Reference Signal parameter.
Does the BPP Reference Signal parameter change state?
Go to Diagnostic Aids
Go to Step 4
4
1.
Turn OFF the ignition.
2.
Inspect the BPP sensor and calibrate if needed.
Did you find and correct the condition?
Go to Step 11
Go to Step 5
5
1.
2.
Disconnect the BPP sensor connector.
3.
4.
Go to Step 8
Go to Step 6
6
Test the BPP sensor signal circuit for a short to voltage. Refer to Circuit Testing and Wiring Repairs .
Go to Step 11
Go to Step 7
7
Inspect for poor connections at the harness connector of the electronic brake control module (EBCM). Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 11
Go to Step 9
8
Inspect for poor connections at the harness connector of the BPP sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs .
Go to Step 11
Go to Step 10
9
Replace the EBCM. Refer to Control Module References for replacement, setup, and programming.
Did you complete the repair?
Go to Step 11
10
Replace the BPP sensor. Refer to Brake Pedal Position Sensor Replacement .
Go to Step 11
11
1.
Use the scan tool in order to clear the DTCs.
2.
Operate the vehicle within the Conditions for Running the DTC as specified in the supporting text.
Does the DTC reset?
Go to Step 2
System OK
© 2012 General Motors. All rights reserved.
DTC C0161
Circuit Description
DTC Descriptor
DTC Symptom
11
12
C0161 11
The ignition is ON.
C0161 12
The ignition is ON.
C0161 11
C0161 12
Diagnostic Aids
C0161 11
C0161 12
Test Description
Step
Action
Yes
No
1
Go to Step 2
2
1.
2.
3.
Go to Step 3
Go to Step 4
3
1.
2.
Go to Step 4
4
1.
2.
Go to Step 11
Go to Step 5
5
1.
2.
3.
4.
Go to Step 8
Go to Step 6
6
Go to Step 11
Go to Step 7
7
Go to Step 11
Go to Step 9
8
Go to Step 11
Go to Step 10
9
Go to Step 11
10
Go to Step 11
11
1.
2.
Does the DTC reset?
Go to Step 2
System OK
Transoceanic (07-05-2020)
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Leave the wrong food out for the cat ? J/k
