Anyone else have poor radio reception??
I just took delivery of my new C6 yesterday and while cruising around last night noticed how poor the FM radio reception is. It is constantly popping and cracking even on the closest most powerful stations. I have the Nav/Audio system. CDs sound fine. Any know issues or easy fixes?
Also does anyone know if there is an xm kit to add xm to the nav type system? I'm interested in a genuine gm kit that will work with the stock radio controls.
I think a VERY few have reported this problem, but mine's okay. I just don't live close enough to very many FM stations, so I only get about half a dozen or so. But no popping & cracking on the ones I do get.
Sounds like you need to visit your dealer.
CI-7-8-9-10 Veteran
Cruise-In IX AutoX Winner
St. Jude Donor '05-'06-'07-'08-'09-'10-'11,'19,'22
St. Jude/CI Name Tag Designer
Yikes! I've had a lot of problems with my C6, but that is definitely not one of them. Good luck!
As to retrofitting XM, if you can get your hands on a module, the harness for it is already there, behind the trim next to the driver's side rear speaker, and the radio will recognize it the next time you start the car. You'll need to run an antenna wire and install a wart antenna, but that's pretty simple, and you'll have the option to use a smaller antenna, and mount it in a less obtrusive spot (like somewhere *inside* the hatch).
AFAIK the XM module isn't special to the Corvette. Any late model GM car with XM should have the same module. So you should be able to find one in a junkyard.
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Poor FM
While traveling from VA Bch to DC, I was looking for the NASCAR race. By mistake I hit the auto program button. It auto set only 3 stations. I was shocked.
XM is great though except when at stop lights under an overpass.
St. Jude Contributor
Might be the problem....
Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids may be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid) #03-08-44-005C - (Jan 19, 2005)
Poor Radio Reception or Radio Static/Increased Interference with Rear Window Defogger On or Some Rear Window Defogger Grids May Be Inoperative (Diagnose and Repair Rear Window Defogger Heating Grid)
1997-2005 Chevrolet Corvette...
Condition
Some customers may comment that the radio has poor reception or radio static/increased interference when the rear window defogger is turned on. Also, some rear window defogger grids may be inoperative.
Cause
This condition may be due to microscopic cracks in the electrically heated grids of the rear window defogger. These cracks may cause electrical interference when the rear defogger is on and this could affect radio reception.
Condition
Cause
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
Windshield antennas never work in Corvettes. The car should have a power antenna and this would solve the problem.
St. Jude Donor '08
Originally Posted by jgraditor
My FM reception is a little weak, more spotty then terrible. Can homestly say with the XM, I don't use the regular radio much. $10 a month is well spent in my opinion.
NCM Ambassador
CI-3-4, 9 & 10 Car Show Winner
CI-3-4-5-6-7-8-9-10 Veteran
St. Jude Donor '04-'05-'06-'07-'08-'09-'10,'14, '16
St Jude Fedex Bowl Donor '09
I have noticed mine doing this... I mostly listen to XM.. but on occasion I get the static.. working with dealer now to catch the issue... nothing major... but its there...
St. Jude Donor '05
same problem here... DVD Nav & XM... same problem I will try the AM to FM switch & see what happens....I have to wait 6 weeks for the car to get back from being converted to a hardtop convertible....
I have the 1SA package and radio reception of some stations is weak. No static or noise, I just loose reception a lot sooner than with my other cars.
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I haven't noticed any problems.....after reading a lot of threads on the Forum, I was a little worried I would be disappointed. However, the system sounds surprisingly good and I haven't had any problems with FM reception...so far. I've been so jazzed just enjoying every aspect of the car, at this point it just continues to deliver!
I have also had static in my FM radio...usually occurs 50% of the time....AM and CD are always clear. Selecting AM and reselecting FM does not clear the static problem for me. Have checked all ground connections (battery, motor, alternate) and antenna module connections (between the rear lights)...all conections seem fine.
