[Z06] Advice on the use of fuel injector cleaner
I've only owned my '02 for 2 weeks so I am still learning. It still has low miles on it (3000) and probably does not need it now, but what is the consensus about using fuel injector cleaner on these cars? I like Chevron's Techtron. I owned an L98 (1987) before the Z and although I used the cleaner, I heard that Chevrolet recommended against it because the injectors had a pindle design.
Thanks,
trebor
Thanks,
trebor
Generally it's a good idea to do now & then. either techron or Redline. Both are detergent based and not solvents. the biggest problem reported (so far) is that high sulpher content gas can caues a build up on the fuel level sensor and also seems to gum up the jet transfer pump (tank to tank).
Premium Supporting Vendor
AMSOIL makes a good fuel injector cleaner. Comes in a 16 oz bottle. AMSOIL recommends an initial dose of 6 oz for 10 gallons, then 1 oz per 10 gallon treatments.
I usually run a bottle through my vehicles periodically.
Here is the product brochure:
AMSOIL Performance Improver
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
If you are using a quality gasoline like Chevron, there is no benefit of using a fuel injector cleaner...you will be wasting your money. This info I recevied from ChevronTexaco (although they recommended Chevron or Texaco gasolines, naturally). ChevronTexaco stated that their Techron in gasoline will clean up deposits starting with the first tank of gasoline and then by the fifth tank your injectors and intake valves will be cleaned. ChevronTexaco also stated that their gasoline will clean up deoposits left by other brands of gasoline.
Using a good grade of gas will help keep the fuel system gunk free (chevron with techron) is recommended by GM....also not allowing the tank to be below half full when not being driven for a few days will help prevent water buildup from condensation.
I have never seen an objective, quantified study or research results where the results tell me I should use a fuel injector cleaner such as Techron or any other brand.
Given that, I don't use the stuff and all four of my motor vehicles run great.
I run mostly Chevron gas, it keeps the injectors clean and the gas gauge happy (do a search, the sulphur in the fuels makes the sensor go crazy on many cars, mine too, and since switching to Chevron I have had zero problems).
Les
Les
Thanks,
trebor
Thanks,
trebor
Correction for you
Also, there are numerous objective, quantified studies and research results on Techron. Chevron was the first U.S. gasoline, in all grades, to be classified as "Top Tier", and recommended & approved by various car manufacturers such as GM, Honda, etc. Even before the "Top Tier" clasification, gasolines were categorized as to whether or not they met the "BMW" test: no deposit build up for 50,000 miles. A gasoline with only a fuel injector cleaner will not meet the BMW test.
If you're wondering on where I know this from, I own various oil stocks and I follow the press releases and such. One more thing, tests have shown that within 5 tanks of gasoline, Chevron (and Texaco) gasoline is able to clean up deposits left behind from other brands of gasoline.
Also, Chevron gasoline is a low sulphur gasoline. Ask your fuel guage and fuel pump contact points how they like sulpher (they don't). It costs more money to refine sulphur out of the gasoline. ChevronTexaco is also a refiner. ExxonMobil is also a refiner;Shell Oil Company does not refine gasoline. There is a difference between brands of gasoline and anyone that tells you that "gasoline is gasoline" does not know from shineola.
Originally Posted by Cruncher
Techron is not a "fuel injection" cleaner. Techron is an additive that not only cleans the fuel injectors but also cleans the intake and stops sludge from forming in your engine. By law, all gasoline sold in the United States is required to have an additive package; the cheaper additives contain primarily fuel injection cleaners. So, even using no-name brand gas will keep your injectors pretty much clean but will not keep the rest of your engine clean, will not prevent deposits from forming, will not prevent sludge, will not ...
1 Post
Been using redline FI cleaner for years. It is not a solvent so it can be used often. Works great.. Although I never had a problem, my friends lexus has been pinging and they had to use premium fuel. I gave them one bottle of redline FI cleaner and it "fixed" their pinging issue.
They can now run regular with no pinging.
I use a bottle in all my cars every 5K miles. It is not a solvent and does not dilute oil, gas... Can be found at for about $5 a bottle... A worthwhile investment.
mike
mike
Chevron gasoline is not sold in all states. GM, Ford, and DM all pay to have Chevron gasoline trucked in to Michigan from Kentucky. All three manufacturers use Chevron for their testing and EPA certifications. If I can't get Chevron or Texaco gasloine, I will use Mobil, Exxon, or BP/Amoco.
Octane, not cleaner
mike
mike
Thanks,
trebor
Thanks,
trebor
1 Post
Pinging has to do with octane. If your engine needs 91 octane and you run 87 octane, expect pinging. Why the F1 cleaner "fixed" the pinging is a mystery to me. Does the F1 cleaner state that it will "fix" pinging?
The lexus in question only sees city driving and limitied hwy use... it never gets "real road tuneup". People don't realize its good get on it every now and then to help burn off these deposits...
mike
mike
mike
When you have carbon build-up in the head/pistons it raises the CR which can cause pinging. Cleaning out this buildup will return the CR to normal. Also carbon "hot-spots" can pre-ignite which will also cause ping. Regular use of cleaner can keep carbon build-up from forming..
Hey, I'm bored tonight and just figured I'd elaborate for the helluva it....
Techron does make a fuel injector cleaner sold in a bottle. I would expect the manufacturer to provide a "study". Wonder how unbiased it is?
