[Z06] 2004 thermostat, fan questions, and CAGS questions
Hi guys,
I picked up an '04 Z06 a few months ago and am quite happy with it. It does run hotter than I would like, especially during extended driving in canyons in 2nd and 3rd gears, and the CAGS has bitten me a few times driving in traffic.
I have a few questions:
1. Who makes the best quality 180 degree thermostat for the car? I know the 2004s have a different design than the other C5 years, so I'm not even sure one is out yet.
2. Who makes the best quality programmer that will let me adjust the temperature at which the fans come on, and that will let me bypass the CAGS?
3. Where is the best place to buy this stuff in the Southern California area?
Thanks in advance.
Thanks in advance.
I can only respond to your CAGS question...this is simply a plastic insert ($19.95) that takes about 5 minutes to install. Any reputable auto performance dealer should have one for your Z.
Received 3,037 Likes
Don't know who makes the best quality 180 degree thermostat for the 2004 yet, but you might want to check with Hypertech.
Hypertech and Predator are 2 good choices for programmers to adjust the temperature at which the fans come on. Most Forum vendors carry these.
Most Forum vendors carry the CAGS skip shift eliminator for around $18-$20. By installing this device you will no longer be prevented from shifting into second gear from first during conservative driving. However
it will not prevent the Skip Shift light from still illuminating on the console.
Here are links to the simple istallation:
http://www.ls1.com/link_cags.html
or
http://97vette.com/howto/cags/index.html
or
I'd check with some of our vendors on the thermostat like LAPD, Ecklers etc. As I understand it you'll need something like an LS1Edit or Predator to adjust your fans. That alone can cost you around $400 to $500. I'd do the tuning last to take advantage of any intake/exhaust mods you may do. They can also turn off the CAGS so you wouldn't need to by the $20 by-pass.
But again the tuning should be the last item on your "to do" list to get your monies worth.
Tom
Tom
Personally I would avoid the Hypertech and Diablo hand held units and get your own LS1Edit software. Buy the stat from a forum vendor - I got mine from Vinci as they seem to have one of the best out there. Then you can adjust your fans, eliminate cags and, in the hands of a good tuner, dial the car in as you add mods.
Les
Les
Tom
Tom
Les
Les
Hypertech is working on a 180* stat for the '04s, no ETA. If you want an easy/quick programmer try the Diablo. Best to support our Forum Vendors. Try Shawn at LAPD or West Coast Corvettes (both in LA).
Thermostat
If the coolant runs at 190 on the highway, but hotter in the canyons, a 180 thermostat is a waste of time. Once the temp exceeds the set value of the thermostat, it is wide open anyway. If you are at 200 or higher in the canyons, the 180 deg unit won't make any difference. Check the air path to the radiator. Leaves & stuff can get up in there and block airflow. If temp is a problem, that's the first thing to check.
Z06Jax,
The car has under 1000 miles on it and probably runs around 200-210 degrees when running around 3-4K rpms consistently going back and forth between 2nd and 3rd gears. I'm not too worried about the water temp, but the oil temp will run between 230-240 degrees, which I don't like. I don't want to install an oil cooler or get into modifications since I'm tired of wrenching on cars, and just want to drive this one. What do you recommend given this information? Thanks for your input.
Originally Posted by crznZ06
Z06Jax,
Running at 3000-4000 RPM in low gears in hot canyons and mountain roads burning a lot of fuel at relatively low speeds and high loads will naturally bump the heat loads on the engine up.
To drop your oil temps, you will need to install an $1800 radiator with oil cooler built in, it will keep your oil close to coolant temperature.
4000 rpm in 3rd on the Big and Little Tujunga Canyon Roads scares the shiite out of me, and I have been there many times... =;-]
If you're in Orange County, go to either West Coast Corvettes in Placentia or Corvette Mike in Anaheim. Two very good places for parts and service. If you're in Los Angeles, go to LAPD.
I think your temps are fine, the only thing I'd do is go with a little thicker viscosity oil, such as the Mobil 1 0W-40 when running much over 220 oil temps.
Z06Jax,
St. Jude Donor '15
Hi guys,
Thanks in advance.
Thanks in advance.
here's a tutorial i made up for vinci for the programmer. http://www.stealthram.com/vhptuner.htm
