[Z06] Competition Mode
Competition Mode
Does anyone know what the competion driving means on your dashboard when holding down the traction control button for 5 seconds? I have asked at dealerships and no one seems to know. :D
Re: Competition Mode (MikeNMaxZO6)
Active handling on, traction control off. It is the only mode I run in. :steering:
Hi MikeNMaxZO6 -
Like Racer44 says - plus I would mention that if you hit reset, the comp-mode message goes away. Took me a while (and the good folks here) to find that one out...
BTW - I used to run in comp mode all the time - now I just shut it off alltogether - I really do not want brakes dragging anytime at all - just my opinion.
best regards -
mqqn
best regards -
mqqn
Re: Competition Mode (mqqn)
Hi mqqn, with my car being S/C'd I would be a fool to run with everything shut off. The car spins the tires immediately when you get on the loud pedal, even at speeds up to 75 mph sometimes. When it starts to spin so quickly it likes to move violently one way or the other. If I never had it in comp mode, it would be 360 degree mayhem. It happens just that fast. :cheers:
Re: Competition Mode (Racer44)
With traction control on,your initial timing is advanced over that when it's shut off,however when the wheels begin to spin the timing is the first thing to get
pulled,then the brakes are used and then the fuel is shut off for a second.
With the traction control off,none of this happens.The tires just spin,spin ,spin.
Active handling will help keep the tail following the nose even when traction
control is off (as in Competition Mode)
no you wouldn't.
people have driven cars with way more power than you have, on way crappier tires, on less sorted suspensions, before the days of traction control.
learn to control the right foot.
Re: Competition Mode (jackmott)
no you wouldn't.
Definitions:
1) Traction control - Fuel is cut by the computer when it detects that the back wheels are spinning at a different rate from the front wheels.
2) Active Handling - Computer applies antilock braking at any single wheel or multiple wheels if needed, and cuts the fuel (even if you are pushing the gas pedal) when it detects that the front or rear of the car is travelinig at a different rate than the other... i.e. yaw rate or fishtailing.
In normal driving mode, both of these systems are active.
If you push the button once to turn these systems off, then you are in full control of the gas, breaks etc... The computer will not correct any errors.
If you hold the button for 5 secs and enter Competitive Driving, the computer turns off traction control which controlls fuel and allows you to keep the tires spinning for burnouts etc... but keeps the active handling engaged so that it will apply braking when fishtailing is detected.
I hope that this is both correct and that it answers your questions.
:rolleyes: Why take the chance? Going around a curve, as I mash the throttle in third, hitting a slight rise , instant sideways. Control my right foot? :confused: No thank you, no time. I'll stick to competition mode. You can be the "race car driver", I will be the "don't take a chance a wrecking my car driver". :seeya
AH is a god send for street driving.
you could get a buick
Hi Racer44 -
:eek: - Mine has not scared me as yet - and I still like a little sideways with my acceleration pie, but if it started kicking me at 75, I would likely reconsider that... :thumbs:
best regards -
mqqn
[Modified by mqqn, 2:50 PM 10/24/2003]
...car spins the tires immediately when you get on the loud pedal, even at speeds up to 75 mph sometimes...
best regards -
mqqn
Hi Racer44 -
best regards -
mqqn
best regards -
mqqn
Great definition Piranha! Your detailed information is exactly what was needed! :cheers:
[Modified by Green Goblin, 5:02 PM 10/24/2003]
1 Post
Re: Competition Mode (Green Goblin)
It's the unforseen "emergency maneuver" or "slight miscalculation" that makes Active Handling so valuable for day-to-day driving, imho. Several Forum members have found that out the hard way....
Re: Competition Mode (thevettenet CA)
I built a little circuit that taps into the traction button and the armrest lighter for power. This new button switch now "holds" down my traction control button for me when I tap it and let go. A little 555 circuit coupled with a relay, and now I have a new little black button I just hit when I want comp. mode! The pic here is the second smaller version I made, back when I was thinking of making and selling these on a case by case basis.
I personally really like comp mode and use my little creation quite a bit! You can get the car sideways pretty easily still in comp. mode, so don't get a false sense of security by having active handling on. :cheers:
[Modified by TeamSpeed, 2:59 AM 10/25/2003]
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Re: Competition Mode (TeamSpeed)
TeamSpeed
Your idea is FANTASTIC! Would you mine if I ask you to provide me the schmetic and the wiring diagram for hooking it up?
I use CM alot and this would be cool!
Bill Curlee
Bill Curlee
Re: Competition Mode (Bill Curlee)
I will try to write up the schematic for you. The hard part is finding the relays and connectors to push into the existing wiring harnesses. What stopped me from selling these was that I didn't know what kind of box to put my circuit in. I was going to sell these for $30. My prototype, which is the one I am using on my car, is about twice the size of this one, and I just have it sitting under the traction/air bag switch plate with tape covering the back side of the board to protect it. This works well, it just doesn't have that finished look.
I could use you as a guinea pig? I would send you the one I have as is (no box around the circuit) and you provide an assessment of what you think after you install it. The wires are bit stiff so working with this is a little hard, but the design is such that you just plug connection pins into the back of the 2 harnesses you need to tap into (power and traction switch), drill a hole for the new switch, put the switch in, and connect it. No soldering and no wire tapping. Give you your address, and after I get a chance to write up installation directions, I will send it to you.
