[Z06] New Best in the Z06
New Best in the Z06
Went to State Capitol here in Baton Rouge last night.. Forecast was for temps in the mid 50's with humidity @ 60% going up to 70% as the night went on.
Only change since last time was my airbox... I removed the Halltech T1 and replaced it with the stock airbox (minus the front cover) and a K & N
We got there when the gates open and had enough time for the car to cool down... Only got three runs
1st Run
R/T: .522
60: 1.929
1/8: 7.969
1000: 10.271
1/4: 12.221
MPH: 115.75
2nd Run
R/T: 2.715 yeah, I know.. I staged too deep, had a brain fart when the top lights went off and decided I needed to back up and restage.. as I was doing this, the yellows started to fall and I just put it back in first and revved up to 5k and launched.. lol
60: 1.859
1/8: 8.086
1000: 10.499
1/4: 12.508
MPH: 112.72
My time was off because I missed third.. Would've been a good run too..
And the new best:
3rd run:
60ft: 1.764
1/8: 7.710
1000: 10.009
1/4: 11.954
MPH: 117.69
:hurray: :party:
[Modified by 94Lt1Vette, 9:03 PM 3/1/2003]
1st Run
R/T: .522
60: 1.929
1/8: 7.969
1000: 10.271
1/4: 12.221
MPH: 115.75
2nd Run
60: 1.859
1/8: 8.086
1000: 10.499
1/4: 12.508
MPH: 112.72
And the new best:
3rd run:
60ft: 1.764
1/8: 7.710
1000: 10.009
1/4: 11.954
MPH: 117.69
:hurray: :party:
Re: New Best in the Z06 (94Lt1Vette)
For some reason it didn't add my sig.. One more try:
Edit: Still not working... Oh well, I'll copy and paste:
2002 Electron Blue Z06
Bone stock dyno @ 2400 Miles: 352.3rwhp & 344.6 rwtq
Previous best track times:
Street Tires, Halltech T1, K & N: 12.53 @ 113
Nitto 555R, Halltech T1, K & N: 12.18 @ 114.30
Current Mods:
B & M Ripper Shifter, Stock Airbox with Ziptie Mod, K & N filter, Nitto 555R Extreme Drags 275/40/17
Best Time with current mods: 11.954 @ 117.69 with a 1.76 60ft
[Modified by 94Lt1Vette, 9:05 PM 3/1/2003]
Current Mods:
:cheers: :cheers: Congrats! New Member of the 11 Second Club! :thumbs:
Great guns all, but the last---Super! :chevy :flag :chevy :flag
Wow! Very good. A couple of questions/clarifications. So you actually went quicker/faster with the stock airbox than a Halltech? What is the ziptie mod? Also, best launch is at 5000 rpm? I have had my '01 to the track only once, and ran 12.81 at 113.1 driving like an old lady (2000 rpm launch, no WOT shifts, etc.). That was in 90 degree heat too. Any tips would be appreciated. :cheers:
Re: New Best in the Z06 (fast455)
As far as shifting goes, I'm basically speedshifting (lifting only slightly on the gas as I shift) when the HUD's shift light illuminates. I've been told that the HUD shift light is wired directly to the PCM, which is the most accurate RPM reading.
Going back to the Halltech.. With an 01, you will probably see some pretty nice gains, but I just wasn't impressed with mine. I took it off for two reasons:
1) The lean code it kept triggering made the pcm run the car rich, robbing power.. this could've been due to poor install or it might be the intake.. Dunno
2) I autocross every now and then and I wanted to stay in Super Stock class while keeping the extra gain in HP.. the zip-tie seems to give me that gain while staying basically stock.
-Cliff
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cliff,
How much fuel do you carry in the tank? Your optimum tire air pressure (street and drag radials)? Competition mode? Or "off?"
Re: New Best in the Z06 (Gaijin)
Cliff,
Tire pressure... When I was on street tires, I tried running it at 20, which is waaay too low (I never considered the fact that they are low profile tires).. A fellow Z06 driver told me later than 25-27 is optimal for the trackm but by then I had drag radials.
On Nittos, I cut my best 60ft times at 18 psi. Anything less than 16 will get poor traction..
I always run in competition mode.. I like having that extra barrier of safety in case I hit a patch of oil or something down the track.
Cruise-In I Veteran
Thanks...good info to have. One more question. Your dyno mentions 2400 miles. How many do you now have? Of course, this question has more to do with break-in miles over anything. Had similar experience with my ZR-1. First dyno numbers were lower than some years later, with a bit more miles (over 10K at second dyno).
I think a lot of my mph increase has to do with the airbox changing.. The lean code caused the PCM to dump fuel on the mixture.. Although I can't confirm this (other than to say that I threw a code every time I went to the track and it was the same lean code each time).
I'm confident that had I used the ziptie setup on street tires, I would've seen at least 116+ traps and a few tenths lower in my ET.
Cruise-In I Veteran
Many thanks....hope to see you at the coming Corvette Forum Cruise-In. By then, you'll really have the black beastie dialed-in. You can give me some pointers. I still have not had much driving with mine and am concerned on loading it up at the drags. Probably later in the summer when I get more miles chalked in.
Funny you mention the traction control. I never gave it a thought when I had my ZR-1 (1990). And use to do 6K shifts in it. I even use to do the 55 mph down to second gear and catapult runs to 130 mph. The rear end would sway a bit and grab traction like a "bat out of hell."
Now, with my Z06....I'm even apprehensive in going to "competition mode." Guess I just need to increase my comfort band with the new ride. Get some more seat time.
BTW, she's a blue beastie, not black.... Blue is faster than black :D
Cruise-In I Veteran
Sounds like an "invite" for a nice road trip to Baton Rouge (by way of the Big Easy). You might just get a knock on the door one of these days.
Good luck and take it easy on the natives......
:seeya
:seeya
:seeya
:seeya
Cruise-In I Veteran
Cliff,
Got you "bookmarked." And most certainly will let you know if the trade winds blow me down that way.
Later,
Larry
Later,
Larry
