[Z06] Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time.
I might have missed it on the previous posts but when the twilight sentinel function is turned on, on the Z06, the headlamps pop up when the car is running, even during the day. I didn't expect this as my coupes headlights pop up only when it is dusk out. Really don't care to have my headlights on during the day so I will be reverting it back to stock. I should have picked up on this when our brother(s) in Canada were mentioning how they were turning it off because they didn't care much for it. Raul P.S. At least my mechanic waived the charge when he figured it was not what I wanted. :cool:
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (muscle cars)
Something is wrong with yours, our cars lights pop up too early at dusk, but they do not pop up in broad daylight. :cheers:
[Modified by racer44, 2:54 PM 1/11/2003]
Don't you need the light sensor? Or is it already installed, just not in use. Iwould think that without it the Computer thinks it is dark out.....
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (Z06 Quin)
Yes, that should not happen on Canadian cars. The lights do pop up a bit early (ie. when it's still a little bright out), but not during the day. Have the dealer fix it.
Can't you just turn the feature off on the DIC instead of removing it with a Tech 2?? This way you could try to figure out what is wrong either today or later.
I don't believe the Z06 has the Twilight Sentinel option? I just went back and checked the book and it wasn't available on 2002 Z06's, unless they added it for 2003?
Jim
Jim
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (hcvone)
With a Tech II tool you can program the light sentinel option. ;)
I am not sure why anyone would want this feature anyway. My Jeep Grand Cherokee has it and I always leave that feature turned off. If I want headlights I turn then on. If I don't want headlights I turn them off. I do not see why this needs to be automated.
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (rbartick)
**EDIT** I will be disabling them on my Z06, using the tech tip from another forum member or using tech ll.
[Modified by racer44, 1:10 PM 1/14/2003]
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (racer44)
I love it! never have to worry about turning them on
never locking the door then realizing I left the lights on
Received 1,767 Likes
I have it on my Grand Cherokee and my M5 and never use it, that was the reason I got the Z06 because it did not have the sentinel. :lol: :lol:
With all due respect, I just don't get that.
Could someone confirm that if the Twilight Sentinel is activated thru Tech 2 on the Z06......... do you have the 2 settings on the DIC for disabling and for interval timing like the coupe and 'vert?? Or is it like Canada where its just "on"
Re: Twilight Sentinel: turned on, on the Z06, now the headlamps are up all the time. (TexasRedZ06)
I had the Twilight Sentinel turned back off today. According to the mechanic my Z06 does not come with a light sensor on the left hand (drivers) side. Right now it is just a hole as was posted above. When it was turned on the DIC would show Twilight- on, without an option to turn it off. Once it was turned back off with the Tech 2 the display went away again. I have Twilight Sentinel on the 2001 Coupe and Impala SS for that matter and was pleased to read it can be activated on the Z06. Well I guess not in my case. I certainly am not going to the trouble of buying a sensor and installing it. It's just not worth my time. :rolleyes:
Twilight Sentinel is a good safety feature feature on my truck but not a cool thing on my vette. If I can find somebody to shut this function off I will.
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
There is a photo cell located directly above the right control panel (fuel, gauge, etc. function buttons).
[Modified by Gaijin, 9:51 PM 1/14/2003]
Location: www.ncminsurance.com Bowling Green KY Home of the Corvette!
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
St. Jude Donor '07-'08
Press it once, you will see the first prompt come on the DIC. Click the reset button to where it says off. You will have it shut off.
:cheers: :cheers:
Re: (Adam Boca)
Shaky: Go to the options button on the right side of the steering wheel.
:cheers: :cheers:
:cheers: :cheers:
Re: (racer44)
wow, thats not cool....
All USA cars this will work! :yesnod: :yesnod: :D :D
