[Z06] What did GM do to get to 405 HP
Location: Winter Jam I and II Veteran, Bahama Jam 2005 Veteran
CI 4, 5, 7, 9 & 10 Veteran
St. Jude Donor '03-'05-'06-'08
I know the 20HP and 20/lbs of torque. But, What I am looking for is what did they do differently from 2001 to 2002 to add the 20HP?
Also, what are the differences in the '01 vs. '02?
Re: What did GM do to get to 405 HP (edv2122)
Intake mostly
Re: What did GM do to get to 405 HP (brewtoo)
Cam, intake, eliminate pre cats, lighter liquid filled valves (for the more aggressive cam).
Re: What did GM do to get to 405 HP (agentf1)
:D
Re: What did GM do to get to 405 HP (LT1pwrd'94)
The reason I ask is that I am looking at an '01 ZO6 and was wondering what it would take to get the 405HP?
1 Post
Re: What did GM do to get to 405 HP (Wolf1171)
-02/03 Exaust center section (with newer cats/no pup cats)
-02/03 Intake box lid
-02/03 MAF Mass Air Flow Sensor
-02/03 Cam
-02/03 Valves (intake & exaust)
-02/03 Valve springs
Keep in mind these are just the things they changed on the motor to get the 20hp. They made a few other minor changes between 01 and 02. Such as revalved rear shock, changed the sway bar end links, and added HUD.
If I were you, I would just get an 02 or an 03.
Buy the 2001, put an aftermarket cam (like MTI ) headers, intake and pulley on it and get 400 RWHP!! Problem solved! My friend has a 2001. When we were both pretty much stock, I was killing him. When we both got pretty much the same cam and bolt ons it was even, so then i had to go get heads!!!!
