[Z06] Hi new guy with ???
Hi new guy with ???
I am looking to buy a Z06 2002 to 2004. What kind of power will I be able to get with everything but a S/C or NOS. We want to go track racing and those are not allowed. I'm guessing with the cars that normally show up I will have to run 150-ish in a 2000 foot straight with a ~40 to 50mph corner entrance.
Dave
Dave
Does that mean you have 2000' of accelerating plus room to brake? Or 2000' total before you enter a corner?
If the first then you shouldnt have a hard time hitting 150's if youre entering the straight at 40+mph... but if its the latter option then no way in heck is that going to happen.
OK so i checked with my buddy who has a 2013 Zl-1 Camaro. the straight total is 2000'. The entrance speed is around 60 and it's a 300 to 400' breaking zone. He gets ~140ish. at brakes. A stock 2002 to 2004 won't keep up, i don't think, close but not quite. so how much more power/ brakes will i need to hang with him?
Dave
Dave
You probably need about as much power as your friends ZL1 to hit 150's... Youre about 1000 lbs lighter so theres your 10+ mph.
1) rotational mass is the first thing you shoudl consider losing if you are doing a Roadcourse/auto x type racing. Big sways, good coilover and a loss of unsprung weight means you can carry a higher speed through turns, which that ZL1 will never be able to do.
2)the c5 weighs a good bit less than a zl1. if you shed weight appropriately you can be as low as 2900lbs(my frc is 2976lbs w/me in it)without a driver. keep in mind that 100lbs is a .10sec in the 1/4 or an addition of roughly 40hp.
3) learn to cut a line before you even give a flying **** what other people run. A good entrance and exit through the apex of a turn allows you to maintain a ton of speed with the right tires. Ride with someone who is a good driver, not neccessarily your buddy, watch the way they enter and exit turns, when to downshift/upshift and apply gas through the apex and proper exit of a turn.
These key areas are what win races. This is why the Cx.R teams crush ****ing everyone with a lesser hp car than alot of the others on the same tracks.
