[Z06] TI Exhaust
TI Exhaust
Is there an efficient way to remove the stock TI Exhaust with the car on jack stands? I have no access to a lift and I have the car up in the air as far as it can go. Looks like the next step is to cut the exhaust but I really don't want to go this route. I am literally 6" away from clearing the passenger side over. In looking at the axle shaft, it may be worthwhile to remove it to give me the clearance I need but I would greatly appreciate any insight on this. TIA
-John
-John
-John
-John
Good luck!
I removed mine intact in my garage on jackstands when I had the bypass mod done. It was easier than I thought it would be. I did use the larger size jack stands for the rear and had the front on ramps. You do have to get the back up fairly high to make room for it but it was fairly safe and easy imo.
St. Jude Donor '08-'09-'10-'11-'12-'13, '15,'21
When you're ready to put them back you might want to consider this mod...
These pipes are mine:
74Weld
74Weld
