[Z06] looking for a +12 volt Key On power source in my 2002 z06
St. Jude Donor '14
anyone know where i can find a +12 volt Key On power source in my 02 z06?preferably a wire thats close to the clutch switch and in that area.what color wire???...im kind of worried useing a multi meter,for 1 i dont know how to use one and 2.i heard if i poke the wrong wire,my airbags will deploy..
Yellow wire from ignition switch, dont cut just take insulation off and tap it or connect and wrap it by tape. this will be your switched power (battery voltage when key is ON). Yellow connector belongs to airbag, ignition switch connector is Black. Remove knee panel and another black plastic panel pull down ign switch wires and tap that yellow...
St. Jude Donor '14
