[Z06] Completed my "Budget Bigger Brake Kit" and Other Goodies Installed!
Gentlemen,
Like many of you, I've never been a big fan of the tiny rear brakes on this car, especially with a large 19" open-wheel design.
I did a ton of research and went back and forth on multiple set-ups: C6Z's were at the top of my list until I found out they wouldn't clear my current wheels. I also contemplated Baer Eradispeeds +2 set-up but ultimately never truly felt they were worth the $1,400 price tag just for rotors alone. That's already pushing into C6Z brake territory when all is said and done.
So, my next logical plan was stepping up to C6 Z51 sizes. Ultimately, I decided to go with C6 Z51-sized DBA T3 4000 series front and rear slotted rotors. I also had some other goodies to install as well. Details are below.
Parts list:
- C6 Z51 DBA T3 4000 slotted front rotors (Part # 42990S)
- C6 Z51 DBA T3 4000 slotted rear rotors (Part # 42991S)
- Front Hawk Performance Ceramic Pads (Part # HB247Z575)
- Rear Hawk Performance Ceramic Pads (Part # HB248Z650)
- Front C6 Z51 relocation brackets (Part # 88964166)
- Rear C6 Z51 relocation brackets (Part # 88964167)
- Doug Rippie Motorsports SS brake lines front and rear
- Brembo LCF 600 Plus brake fluid
- Doug Rippie Motorsports re-valved Bilsteins
- GM T1 Sway Bars, end links and VB&P Poly Bushings
- Anti-Venom mod
The new brake set-up increases the front diameter 0.8" and the rear diameter by 1.2"! That really helps reduce the brake-wheel gap which is exactly what I was after.
C5 Rotor Size
Front: 12.6"
Rear: 11.8"
C6 Z51 Rotor Size
Front: 13.4"
Rear: 13"
Before I get to installation and pictures, I have to give a huge shout out to both KNS Brakes and Doug Rippie Motorsports for giving me excellent advice, information and customer service throughout this process. I haven't seen a lot of people do this set-up on C5s so I felt like I was treading a bit into unknown waters but in the end, everything turned out excellent and I didn't have to make a single run to a parts store. This set-up is as complete as it could get.
Installation was an absolute breeze. Fitment was spot-on and perfect. No trimming on the calipers needed. Just bolt-on and go. I find it hard to believe there's a better kit on the market for the price. I couldn't be more satisfied!
Ok, enough talk. If any of you have specific questions I'll answer as best I can. Picture time!
Here's what I was looking at Saturday morning:
Front shock and brake set-up on:
Wheel on:
Front set-up complete with new GM T1 bar:
Up close:
Rear set-up complete:
This one's just for reference on the rear. Here's an older pic I found that'll give everyone a good comparsion of the stock brake-wheel gap:
New set-up:
Happy modding!
Parts list:
- Anti-Venom mod
C5 Rotor Size
Front: 12.6"
Rear: 11.8"
C6 Z51 Rotor Size
Front: 13.4"
Rear: 13"
Wheel on:
Up close:
New set-up:
Happy modding!
For cosmetic purposes, I went with the Baer +2 rotor/relocation kit several years ago, and it wasn't anywhere near $1400; more like under $700. I didn't do any other, actually functional brake mods, because I don't race. If you are using it for racing, I'm sure the better pads, and fluid/lines will help in that department. Someday, I'd like to upgrade my calipers, too, but the "need" isn't there. I've really liked the rotors over the years.
I just priced it out on Southern Car Parts.
Fronts are $745
Rears are $645
$1,390 all in for just rotors and brackets.
Brakes are really 70% pad, 20% rotor and 10% caliper. Ironically, the calipers are the most expensive part.
The nice thing with this kit though is its versatility. Tons of options for other C6 Z51 sized rotors if one decides to switch down the line.
I've started looking into this too, cheapest I've found is about $500 total. Just over $200 for the Z51 brackets and just under $300 for Z51 rotors, both new stuff up for auction. Moving up to the DBA T3 rotors makes it more like $950 total.
The Baer stuff might be good but in addition to being roughly 50% more expensive initially I have concerns about running expensive drilled rotors on the track (maybe Coleman or somebody could make some slotted rings to replace the drilled stuff?) and also concerns about shifting the brake bias that far to the rear. The Z51 setup shifts it a little bit, but the Baer setup shifts it a LOT. It probably feels better with light to moderate braking but I wonder if it would make threshold braking dangerous.
If I put the right numbers into the TCE calculator, I got 66.1% front bias with stock C5/C6 setup. C6 Z51 sizes moves it down to 64.5% front and the Baer +2 setup all the way down to 60.8% front.
Man, that's a nice setup. I never thought about the Z51 brakes.
I'd love to have the C6 Z06 setup (they will clear my wheels), but if the Z51 is quite a bit cheaper, I may look into that. I have 18/18" wheels, so wheel gap would be even better in the rear.
You must have gotten the deal of a lifetime then, or they've significantly upped the price over the years.
Fronts are $745
Rears are $645
Fronts are $745
Rears are $645
No problem! Glad to help
Very nice
I can 99% say you won't have any issues. The C6 Z51 uses an 18/19 set-up from the factory and because your wheels don't have a dish, clearance for the calipers won't be an issue. It's a great upgrade!
Did you ever get a difinitive answer as to if this set up will work with the OEM size C5z wheels?
http://forums.corvetteforum.com/c5-t...06-wheels.html
http://forums.corvetteforum.com/c5-t...-a-c5-z06.html
not a bad idea for $200 in brackets. makes rotors cheap and easy to come by which is the part i like. you get a little more heatsink and the cosmetics for $200 in brackets. i would assume rotors prices between the c5 and c6 are similar
I have read both that the 17" C5Z wheels do fit and do not fit in different threads. Soon I will be able to put that question to rest though as I am getting these brackets and rotors to put on my car. I have all 3 C5Z fronts available to test fit: gray alcoa, gray speedline, polished speedline. I'll post the results when it happens.
Another member in one thread even said that the regular C5 thin spoke 17" fronts clear the C6 Z51 brakes, so who the hell knows...
