[Z06] Do 315/30/18 fit on a z06?
315/30/18
315/30/18 michelin pilot sport cup I needed a spacer, kuhmo v710 fit fine, with hoosiers I need a spacer. Hoosiers are racing slicks
A lot of big tires in 17/18" sizes have been discontinued over the past few years. The only 315/30/18 street tire available today as far as I know is the BFG Rival... but you'd have to run that at all 4 corners on a C5 since they don't make Rivals in any useful 17" size to pair with it.
Stuffing wide and wider low profile tires on a particular wheel width isn't going to give you a whole lot. Sidewall will start to bubble out which does not look good IMO and it negatively affects handling. 295 is stock on the rear wheels... I would go up to 305, but that's about it. Tire specs list their "approved" rim widths limits and their ideal width as well.
