[Z06] Lowered c5 z06 affecting 1/4 mile times?
So I lowered my z06 with those lowering bolts from eBay. Will that affect my 1/4 mile times at all? If it does where can i get the factory bushings? Like an idiot, I threw them away. Thanks fellas!
If you didn't get it aligned, you'll lose traction easier than before. You also have less weight shifting to the rear of the car when you launch, again resulting in more wheel spin than before. Unless if you're running tall slicks, I'd lift the rear up a bit for the drag strip.
