[Z06] Trunk Issue/Power Windows/Antenna
Hello All
1. Has anyone experienced a trunk that doesn't always open quite enough to get your fingers in to pull it open? Any suggestions for solving this issue?
2. Anyone out there know how to convert the power windows to include Auto-Up as well as Auto-Down? Car comes with Auto-Down power windows. Any way to make them Auto-Up as well?
3. I am looking to remove the stationary antenna and put in a power antenna. I have been told that the car will accommodate a power antenna. Anyone have any suggestions/recommendations?
Thanks!
Thanks!
Hello All
Thanks!
Thanks!
http://www.corvettemods.com/Corvette...ST_p_4978.html
2. Never heard of this being done, but it would be nice. I will stay tuned to see of there are any suggestions.
3. A power antenna from a C5 convertible should work. Track down a shop manual and it will show how to install and wire. You can order one from one of the OEM parts vendors here.
1. common issue. Corvette Mods (vendor here) as a solution
That's what I did
I went with this rather than screw around with the power antenna and add weight (I'm OCD with weight on this car):
http://www.cravenspeed.com/products/...y-Antenna.html
Rickster1
I ordered the trunk solution you recommended from Corvette Mods. I appreciate your timely response. It was very affordable, but appears to be quality.
We'll see how it works. Supposedly, installation is less than 5 minutes.
DILLI1
DILLI1
rjwz28
Thanks for your reply. I want to do something with the antenna that came with the Z06 - it is too long. I am concerned about someone breaking it off just because they can...you get what I am saying? People do stupid things just because they can.
I was considering a power antenna. The disadvantage is price and the fact that they have to pull up the interior a little to run the cables to the radio. I have not purchased a nav unit yet, so I am currently running the stock radio.
The Stubby looks like a great option! How has your reception been? I see some people complaining about the decrease in reception.
To be honest, I am NOT a big listener to any radio station. I like my iPod and would be using it most of the time. I do want the ability to use a radio, though, and if this unit would provide good reception I would consider it.
Then again - I see where people say the reception is really good and that there is no noticeable difference between this antenna and the original. It seems like it would look awesome on the car. I am thinking about getting one.
I use the Craven Stubby and may have a lost a small amount of reception, but not enough to be an issue for me. I like it.
Just a note, I have the trunk spring as well and after awhile it will compress down where it won't open just like before. I think it is an item that has to be replaced from time to time.
Barrett
