[Z06] HP/TQ #'s ????
HP/TQ #'s ????
I am taking my 02 zo6 for a tune what kind #'s should I expect:
38,165 k on the clock
Vararam
Ported TB
ported and polished 243 heads
Texas speed cam .233/.239 598/608 on 112
1 7/8 kooks
Ls9 clutch
Any input appreciated.
Vararam
Ported TB
1 7/8 kooks
Ls9 clutch
Your Heads/Cam (although I don't know enough about yours specifically) should put you around 440+ to the ground easy with the right tune
VPP
Hell this thing should run low 11's. If i can can get a 60 ft in the 1.7's My 2012 Mustang ran 11.69 with tune slicks and front runners. It weighed 3650 with me in it and put down 399 to the wheels. This thing feels a lot faster than the stang.
Similiar cam ( 232,236/ 595,601/ 113 ) but stock heads put 420 to the tires so 450 could be possible I think.
[QUOTE=malibu78;1586580918]My heads are stock to just ported and polished have you run your car down the track?[/QUOTE
No. But for what its worth it has always felt just as fast as any of the bone stock C6Z's I have had. ( 06,07,09 )
[QUOTE=jbp8653;1586581076]Wow 4 z's!!! I wanted c6 zo6 performance for under 25k that's why I went with the 02z with heads and cam. Thanks for the input.
[QUOTE=malibu78;1586582912]Thank You! Actually have had 27 Corvettes since 1974. 6 Z's. 2 different 02's, 3 different C6Z's, and a ZR1. Also, I remembered yesterday, I had a new 05 C6 Z51 ( traded my first C5Z in on this one ) with 4 speed. I modded it right off the bat with the same cam that I mentioned and headers. It put 415 to the tires. It ran in mid 12's on stock tires with horrible 60 foot times ( 2.25 or so ) at around 117-118 mph. Easy 11 second car with some traction. Hope this helps
