[Z06] Carbotech brake pads from Amp'D Autosport
#42
Supporting Vendor
St. Jude Donor '11,'13
I appreciate your business
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
#43
Supporting Vendor
Smarter construction.
Only Carbotech uses a proprietary Ceramic and Metallic brake construction, not the carbon and iron used in conventional brake systems. Since carbon and iron combine to form carbide, which is used in cutting tools, you can imagine what those brakes are doing to your rotors.
Carbotech Performance Brakes utilize true race compounds that are “rotor friendly,” eliminating the grabbing and locking up that keep so many drivers and race cars from performing at their peak. You want to go deep to gain those precious fractions of a second before you need to brake, and only Carbotech brakes let you do just that. In every turn, all race long.
#47
Supporting Vendor
When you take your car to the track, you want to know you can charge aggressively into the corners and be sure your brakes will shear off that speed—giving you maximum control without unnecessarily sacrificing pace. Just call us and our racing specialists will help you determine the perfect brake pad compound for your car and your style of driving. Carbotech brakes are designed to allow you to “Go Deep!” while being particularly friendly to your rotors.
#49
Supporting Vendor
If you guys or gals are looking for Brake Pads Street or Track we have plenty of Carbotech compounds ready to go. We offer forum discount. You can use promo code z28 when checking out or call me direct at 216-780-8825. If pre bed is desired please call option will be on our new site shortly.
#50
Supporting Vendor
Designed by racers for racers, Carbotech brakes can be specified to meet the needs of your car and driving style. Just give us a call at 216-780-8825 and we can recommend the compounds that will be perfect for your front and rear pads, assuring that they perform together with optimum effectiveness or if you know what you need please go direct to http://www.ampdautosport.com/servlet/StoreFront and use promo code z28 when checking out for forum pricing.
#55
Supporting Vendor
Working Saturday give us a call or order direct from our site. http://www.ampdautosport.com/servlet/StoreFront
#59
Supporting Vendor
Working Saturday Phones are open and as always http://www.ampdautosport.com/servlet/StoreFront Promo code z28 when checking out for forum pricing.
#60
Supporting Vendor
Back to work Tuesday
Another characteristic that makes Carbotech-Ceramic™ materials attractive is the absence of noticeable dust. All brake pads produce dust as they wear. Carbotech-Ceramic™ compound ingredients produce a light colored dust that is much less noticeable and less likely to stick to the wheels. On that same note, all Carbotech compounds produce a 100% non-corrosive dust that can usually be rinsed off with a hose.
