[Z06] Paint is looking better!
As some of you may remember, I picked up an 04 Vette, the paint was overall good but had some swirl marks. Just got it back from a buddy who owns/runs a detail shop here in town. While it's not perfect, it is vastly improved!
Couple of before
after
And a few more for good measure...
So much construction right now it's tough to keep clean even for a day But the paint looks pretty good now.
Couple of before
after
Not really. You invest in a portacable and use some 3M compound and finish it up with a glaze. In 2.5 hrs time it will look like a mirror. You just gotta know what you're doing. I actually enjoy it so its no big deal....
I won't lie, it looks really good, but without any true sun shots in the paint or a direct light source, it's going to look like glass, especially if a glaze has been put on top. Regardless, the paint does look really, really good.
Okay...When can I bring my BLACK Z06 over to you.... . Tons of swirl marks from previous owner (original owner) for 12 years!! Have plans on taking it to a body shop who does fine work this Spring before showing it anywhere. Just purchased a set of new Gloss Black C6 wheels with the outer red ring installed on the perimeter of the wheels...But will not have those installed until its back from getting the paint finished like brand new....
agreed. washing, claying, washing again, then taping takes at least 2.5 hours much less compounding/polishing the whole car. If you have to use a glaze then you did it wrong.
Don't know why it would take you 2.5 hours to do just that unless your taking smoke breaks or beer breaks... I rinse the car, Wash the car, Rinse the car Wash the car again and while its soapy I then clay bar while its soapy and slick so your not playing around doing 1ft increments with detail spray. I then rinse the car again and dry, Then I can begin my detail. I don't usually tape anything unless I know I will be getting close, Such as the Brake duct and window trim ect. I use 3M 36060 cutting compound for the first step, then finish with either 3M 05996 or Brilliant Glaze. Depends on what I got. This takes me between 2.5-3hrs max... Its not rocket science and I have had enough cars to know what needs to be done to do it... If you think Glaze is wrong then more power to you, But I can tell you my paint will tell you different as well as any real detailer
Well as Long as you are achieving the results you want, who cares right? What do detailers know.... my guess iIs one day you got some bad advice, bought some things and went to town on your vette. My guess is you hazed the ever living **** out out your paint. In a panic you threw some glaze on to hide the haze. After the glaze went on, you had the illusion of a defect free car, I'm sure the new owner was quite pleased to see that when the glaze wore off, he was left a mess.
http://www.ls1gto.com/forums/showthr...857&highlight=
I may have hazed my GTO as well lol
youre correct, glaze doesnt hide hazing (which is caused by compounding) it rather hides swirls and scratches. its your car and obviously you can do what you like especially if you like the results.
