Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-12-2014, 06:28 AM   #1
Medic949
Junior Member
Default Underdrive pulley, any gains on stock
I'm looking at optimizing the power of my stock 2002 Z06. I have seen under drive pulley upgrade packages claiming increase in power. Is there any truth to this and is the power increase worth the money?
Medic949 is offline   Reply With Quote
Old 01-12-2014, 01:05 PM   #2
PeteZ06
CF Senior Member
St. Jude Donor '07-'08-'09-'10-'11
PeteZ06's Avatar
I think its good for 3-5 rwhp... I remember a few people dynoing their cars before and after installing an ASP underdrive pulley many years ago and that was the average. I ran one on my previous cars... not even sure if they make one for the LS7.. something I should look into myself.
__________________
'01 Z06 Speedway White/Black
LS7 427
www.speedinc.com
PeteZ06 is offline   Reply With Quote
Old 01-12-2014, 03:10 PM   #3
0H1Z06
CF Senior Member
0H1Z06's Avatar
I purchased one for my current 414ci.... Powerdyne...
IMO if you are going to change out UD pulley you may as well throw a cam up in there...
Quote:
0H1Z06 is offline   Reply With Quote
Old 01-12-2014, 07:08 PM   #4
PeteZ06
CF Senior Member
PeteZ06's Avatar
You mean a real cam?
My LS7 is heads and cam but just a super small cam, I ran aggressive cams for too long in my previous cars that I really just wanted something tamer this round. Maybe one of these days I'll put in a healthy cam, get a LSX intake and drop my cats and break the 600+rwhp mark
__________________
LS7 427
www.speedinc.com
Old 01-13-2014, 08:59 AM   #5
0H1Z06
CF Senior Member
0H1Z06's Avatar
you know what I meant PeteZ06....
I am opting for the aggressive cam, ported LSX intake, different fuel system, TEA's, Calloway Honker... etc, blahze,... I am chasing the 600 mark that you speak of.... Sorry to get off topic to the OP....
A "pulley" will be nice.... and inexpensive...
__________________
2001 Corvette Z06 Black/Mod Red
LS2 Based 414ci Stroker 520hp/510tq
Built by TRUE STREET MOTORSPORTS
Old 01-13-2014, 12:53 PM   #6
williamb81
CF Member
williamb81's Avatar
I just installed one on my hot rod. Ill post the hp gains in a week or two.
williamb81 is offline   Reply With Quote
Old 01-14-2014, 10:47 PM   #7
ptindall
CF Senior Member
ptindall's Avatar
Location: Guilty of federal crime of loving Mexicans because I'm a liberal bitch in Sahuarita Arizona.
I installed one when my stock one started wobbling and threw the belt. I don't have a before and after dyno but I will say there was no negative side effect.
ptindall is offline   Reply With Quote
Old 01-15-2014, 09:05 AM   #8
Moto One
CF Senior Member
Moto One's Avatar
I have always thought that the reason for under drive pulleys was so that you don't damage the alt/ac compressed from extended hi RPM runs. I was also told that if you are using your car for daily driving (commuting ect) you run the risk of not getting enough spin on the alt to properly keep the charging system at need levels.
Mark.
Moto One is offline   Reply With Quote
Old 01-15-2014, 09:50 AM   #9
Scooter70
CF Senior Member
Scooter70's Avatar
Send a message via AIM to Scooter70
Is 3-5hp worth the hours of labor to just install a damper? (You need to move the steering rack out of the way to change the crank pulley. If you haven't done that yet, it's a pain in the a$$.) Like stated above, if you're going in that deep, you might as well spend the extra hour or two and swap the cam (and springs... and pushrods... and injectors.... and put on a FAST 92 and LS2 throttle body... and AFR heads....).
It's a never-ending series of "while I'm at it...".
__________________
2001 MY Z06
1970 LS1/T56 Coupe (sold)
Scooter70 is offline   Reply With Quote
Old 01-15-2014, 12:38 PM   #10
skyavonee
CF Senior Member
skyavonee's Avatar
http://www.linkedin.com/pub/michael-schiavoni/95/361/940
Quote:
Originally Posted by Scooter70 View Post
Is 3-5hp worth the hours of labor to just install a damper? (You need to move the steering rack out of the way to change the crank pulley. If you haven't done that yet, it's a pain in the a$$.) Like stated above, if you're going in that deep, you might as well spend the extra hour or two and swap the cam (and springs... and...
skyavonee is offline   Reply With Quote
Old 01-15-2014, 01:53 PM   #11
ptindall
CF Senior Member
ptindall's Avatar
Quote:
Mark.
That and the water pump and power steering pump also turns slower opening the possibility of poorer engine cooling and insufficient pump pressure or volume when turned the wheel quickly. However, having done this mod, I can tell you that none of these occured for me.
Old 01-15-2014, 07:46 PM   #12
PRE-Z06
Supporting Vendor
PRE-Z06's Avatar
Quote:
Depends on how much they are underdriven and how much lighter, but I'd say ~3-8rwhp higher side being 25% reduction compared to 10%.
__________________
http://www.youtube.com/watch?v=wNb3maKeytI
http://www.youtube.com/watch?v=vg1OX90xbWY
~422rwhp+Monster Level 2=60'-1.49 1320'-10.99/125.5
Best mph-127.1
Chris, 817-750-2000
PRE-Z06 is offline   Reply With Quote
Reload this Page Underdrive pulley, any gains on stock
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
