[Z06] Project YOLO: The Quest for 100 HP per Liter NA!
#221
2" primaries huh ? That should allow that 434 to breath much better !
How about the top end... anything needed there to reduce all restrictions which was choking your motor ?
Toque
#222
Hence the 30 HP difference.
We'll see what it gains w/ the headers. From there, we'll about going to a big nasty bump stock. This one does drive fantastically though.
#225
How far you think the headers will get you? I've seen where going from 1 3/4 to 1 7/8 did virtually nothing. Is it you or the C6Z with the heavier internals? I'm assuming you.
#226
The 2" headers my head porter thinks will gain big power. I think 15-20 throughout the curve, he things more. He built the heads for a minimum 1 7/8 header. Literally, he took the "D" shape out of the exhaust port. He's the reason I'm doing this first. After the dyno and final tuning was finished up, he said headers are holding you back. So, I'll be taking that out of the equation.
#228
Received 2,045 Likes
Notice ARH doesn't even sell 1.75" headers for a 427, a modded one needs to breathe even more...as far as the dry sump in the C6Z it actually has been shown to rob a little power as seen in the link below being it doesn't pull a vacuum like a race set-up yet you have two pumps as a parasitic loss:
http://www.hotrod.com/techarticles/e...mp_conversion/
Figure the bigger cam will be worth ~25hp, is that what you were told?
#231
#232
I hope & think the headers are a huge bottle neck. Not from the size, more the port mismatch the wrong way.
Smaller camshaft & let the heads work.....that is the way I like to get err done.
#233
Received 1,679 Likes
crank, wheels?
Yes, me w/ heavier internals. Cranks weight is the same, the rods and pistons are where the weight is added. The TI rods in a true LS7 weight 480g a piece! The callies compstar's I'm running weight over 600. There's a similar difference in the pistons as well. It's strong, and that's good, but that comes w/ a penalty.
#236
Sounds like a plan, I'll take good flowing heads over a bigger cam every day of the week My little 346 with ~13% bore area, a tiny 218* cam and heads that flow ~25% less than yours picked up 7rwhp from 1.75" to 1.875" headers...looking forward to see your gains going to 2"
#237
I haven't seen where you listed what correction factor your dyno shop used for your 554/490 pull.
- Did they correct to SAE?
Good luck with your project.
#238
