[Z06] 18s all around
Old 12-10-2013, 04:27 PM
zeke2u
zeke2u's Avatar
Originally Posted by apollo240
Kinda off topic, isnt speedline who made them for 01? From my reading the 01 wheels were lighter right?
The '01's were Alcoas, forged and IIRC they're marginally heavier. The '02 on were Speedline.
Old 12-10-2013, 04:30 PM
apollo240
apollo240's Avatar
The 02 up are cast right? What i read said forged was lighter, kinda better. Just trying to understand. Im happy knowing i got speedlines though
Old 12-10-2013, 05:25 PM
rjwz28
rjwz28's Avatar
2001 wheels are Alcoa and yes, they're heavier than the 02-04 Speedlines
Old 03-17-2014, 10:57 PM
quick04Z06
Support Corvetteforum!
quick04Z06's Avatar
Do any of you drive the 315-30-18 square set up with factory Z06 rear wheels at all 4 corners on the street? I was wondering if while good for track handling such a set up was tough to live with on the street.
Old 03-17-2014, 11:34 PM
rjwz28
rjwz28's Avatar
It's going to follow lines and cracks in the road a lot more than a narrower front tire, for sure
Old 03-23-2014, 11:48 AM
04silverZ06
04silverZ06's Avatar
Originally Posted by ktlocklear
And a shot with my 315/30/18 squared set up
Absolutely love the look with the 315-30-18's all the way around!
Any spacers required? Also do you have coilovers?
Old 03-24-2014, 10:27 AM
ktlocklear
ktlocklear's Avatar
Thanks.......no spacers required, although I have ran with 5mm spacers on the rear with no issues.....but again, no spacers are required to clear anything. Also, i have coilovers on the car now.......but in the above pic it's lowered on aftermarket bolts
Old 03-24-2014, 12:51 PM
RDnomorecobra
RDnomorecobra's Avatar
yes and as already stated, the car "hunts" in the grooves in the road more. other than that it doesn't present any real problems. I do try not to turn the wheel to full lock however ... depending on your suspension set up you could get a bit of rubbing on the control arms etc. I wouldn't recommend running that large a tire on a street only car.
Old 03-24-2014, 03:31 PM
mikebq
mikebq's Avatar
Default 18' all around
Originally Posted by halp
Due to stock tire availability I am thinking of going to 18 inch rims on the front. planning on using 275-35/18 on stock rear rims for front and staying with 295-35/18 for rears. Looking at Conti Extreme DWs.
Will this set up cause any traction / active handling problems and how will it look vs stock sizes? appreciate any pics with this combo.
I have 18's all around with no problems ...PS2's 275/35/18 front , on 9.5 rim , 315/30/18 with 10.5 rim on the rears with no problems w/ coilovers also. I don't track the car or take it to the drags. No traction or act handling problems, 660 HP ....Going to Toyo R888, need traction.
Old 03-30-2014, 10:31 AM
04silverZ06
Would you be willing post some pics?
PS - I bet you can't wait for this snow to melt - I know I can't! I think you guys got even more snow than we did here in Ontario!
Quick Reply: [Z06] 18s all around
