cant decide what to buy
2003 zo6,18k mi.all stock,needs tires,$23.5k.2nd vette,2001 non z 30k mi.6 sp.new tires ss headers,corsa ex.viram intake.$15.5k.since there both about 400 hp.what to buy ??any thing extra in the z06.the 01 saves me $8k thanks for your feed back.mike
Buy the 01 and boost it!
Seriously. I would say it depends on what you want to do with it. If you're not going to touch it with mods, then I would go with the Z. If you are going to mod it, then you need to make the decision of how much because there is a point at which you will replace enough on either car to not justify the difference other then to say you paid $8k more up front to say you have a Z. Then again, us FI guys are crazy!
Received 3,054 Likes
What is the insurance cost difference? Z06 - coupe - FRC ?
Received 1,101 Likes
Get the real deal. That price is reasonable. No way that 01 ='s the Z in HP with those mods. Aim for 1K less to off-set the need for tires and lock her in.
If not, send me a PM on Z location
I would go with the '01 and save a lot of money.
I don't know the exact hp of the '01 with those mods, but I suspect is is similar to the Z.
The Z has a different transmission that is a little stronger and has slightly different gear ratios to aid acceleration.
The Z has a stiffer suspension and wider wheels/tires. However, you can upgrade the base car quite easily for both suspension and wheels/tires if you decide to.
To me the bigger question is which body style and options do you want. I like the notch back with a trunk (I have an FRC) and I also like to take the targa top off (I have a targa also).
For me, the deciding factor the price difference if they are both similar condition cars.
You should also drive both and see what you like.
Good luck with your choices.
