[Z06] Door locks
Door locks
Ok only my driver side door will not lock or unlock with key fob can use key to open but not fob also when car hits 10mph auto lock works what can I look at thanks
There is a control module in each door that contains the relays.
Two relays control the lock/unlock and there is one for the window.
The relays can be purchased thru DigiKey corp. They aren't expensive.
Plus the specs are better than the originals - they should last longer.
Sorry, I don't remember the part numbers...
I have a link to an old how-to post, but it doesn't seem to work anymore. Says I don't have permission to access it. I guess they moved it to some sort of archive.
It's a shame, that was a great post and I think it should be a sticky since there are so many posts about this problem.
It was this link: http://forums.corvetteforum.com/c5-g...w-problem.html
http://forums.corvetteforum.com/c5-t...direction.html
