[Z06] Shifter has play after Clutch install
Old 05-15-2013, 04:47 AM
Wood81
Wood81's Avatar
Default Shifter has play after Clutch install
My shifter has a lot of side to side play in it even while in gear, and it's hard to get into second at times. It just feels loose and muddy for lack of a better term. Its a 2001 Z06. Never did this before. I just had a shop install a Mcleod twin disc RST so the clutch is not the issue. I am thinking maybe the shift linkage from the shifter in the console itself may be loose. Anyone that can point me in the right direction I would greatly appreciate it. I did a search, but got nothing that can help my exact situation. Thanks in advance guys.
And before someone says take it back to the shop, they are a little ways away and if it's an easy fix I'd prefer to do it myself instead of drive all the way to Daytona.
Old 05-15-2013, 07:57 AM
fisher auto
fisher auto's Avatar
Shaft to shifter is loose! Have to make sure the torks is very tight!
Old 05-15-2013, 08:07 AM
Wood81
Wood81's Avatar
So it's fairly easy fix?
Old 05-15-2013, 08:09 AM
fisher auto
Yes have to pull the console out to gain access but not really a big deal. Should be the problem!
Old 05-15-2013, 08:11 AM
Wood81
Wood81's Avatar
Sweet! Thanks a bunch, I am going to go get on it.
Old 05-15-2013, 08:22 AM
Wood81
Wood81's Avatar
Another quick question... Is there a link with pictures? I know how to get the console off but want to make sure I tighten the right bolts up.
Old 05-15-2013, 09:48 AM
fisher auto
I don't have any but once you get console off unbolt 4 10mm nuts to shifter boot and lift it up. Should see shaft to shifter flopping around towards rear of opening!
Old 05-15-2013, 06:49 PM
Wood81
Wood81's Avatar
This was exactly the problem, it works great now. Thanks!
Old 05-15-2013, 09:02 PM
fisher auto
Glad I could help!!!
Old 05-17-2013, 06:00 AM
Wood81
Wood81's Avatar
Ugh, here we go again. I got on the highway yesterday and noticed that it's tough to get into 6th now instead of 2nd. 2nd still sometimes is tough too, about 5% of the time. Is there a way to align the shifter back to stock specs? Like I said before there were no issues what so ever with shifting before I had the clutch install. Is there some way to measure where dead center is on the shifter? I know that it's causing the problem, my transmission only has 30 ish thousand miles on it and has never been abused. I may change the fluid too, would going to synthetic trans fluid help the longevity of it at all?
Old 05-17-2013, 09:39 AM
lisoundsvette
lisoundsvette's Avatar
Default shifter alignment video here
there is a shifter alignment video here. hope it helps you
http://forums.corvetteforum.com/auto...id-change.html
Old 05-17-2013, 09:49 AM
Wood81
Wood81's Avatar
Thanks, I will try it again.
To Shifter has play after Clutch install
Quick Reply: [Z06] Shifter has play after Clutch install
