Corvette Forum
Go Back   Corvette Forum > C5 Corvettes, 1997 - 2004 > C5 Z06 Discussion
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C5 Z06 Discussion
General Z06 Corvette Discussion, LS6 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Sponsored by
PFYC
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-25-2013, 02:33 PM   #1
SKMCOBRA
CF Senior Member
SKMCOBRA's Avatar
Default Nitto 305/35/18 555R?
Has anyone used these out back on their C5 Z06? It is only 10mm wider than the stock width, but I also know the Nitto drag radials run a little narrower than other brands. This is the closest they make to the stock size for our cars. Any issues with speedometer when running these. It is only 3.5mm higher per side, or 7mm total tire height.
SKMCOBRA is offline   Reply With Quote
Old 02-25-2013, 02:49 PM   #2
nstyzo6
CF Senior Member
nstyzo6's Avatar
I havent used this size on a stock c5 zo6 wheel, but I run them on my 18x11 ccw wheels and have no problems & my car is lowered.
nstyzo6 is offline   Reply With Quote
Old 02-25-2013, 02:53 PM   #3
mooksz06
Junior Member
mooksz06's Avatar
Quote:
I run these out back. Have been great tire. I am running 600whp and they hook well even at these levels. I have had them on the car for 8k miles and not much wear honestly, have probably more than 8k miles left in them.
Only thing is that they will not be good at all in any water
They are not even close to rubbing and they dont stick out of the wheel wells
mooksz06 is offline   Reply With Quote
Old 02-25-2013, 03:58 PM   #4
Quickshift_C5
CF Senior Member
They will work fine. I use the 555R-II versions on the stock wheels. They are a perfect fit. I agree with the guy above, the traction is incredibly good. I dead hook with them at 572rwhp in 2nd gear.
They will also work in rain. I've driven in the pouring rain with them and through standing water with no problems (the back end WILL get loose, so be careful) even when they were worn. And thats with no traction control or stability management (my yaw sensor is defective). Just use common sense and good judgement.
I have about 13,000 miles on mine and the rears are done. The centers are worn completely smooth, no tread pattern. This means ill have to adjust air prssure on the next set. This is with several Dragstrip events, 4 Autocross events, and a whole lot of horseplay on the street. I never do burnouts though, so take that into consideration. The fronts still look practically brand new. I'm only ordering rears this season.
Quickshift_C5 is offline   Reply With Quote
Old 02-25-2013, 09:10 PM   #5
SKMCOBRA
CF Senior Member
SKMCOBRA's Avatar
Yeah I had a pair of 315/35/17s on the back of my Cobra for the past 6 years. I really liked them for a non daily driver tire. I just wanted to be sure they fit good. Did it change you guys' speedometers?
Old 02-25-2013, 09:41 PM   #6
Quickshift_C5
CF Senior Member
No. I compared my speedometer to a friends C6 and it was still accurate.
Old 02-28-2013, 10:33 PM   #7
jmac2354
CF Senior Member
jmac2354's Avatar
I also run them on stock wheels on my z, no issues, other than not too good in rain.
jmac2354 is offline   Reply With Quote
Old 03-01-2013, 01:51 PM   #8
tacman
CF Senior Member
St. Jude Donor '13
Support Corvetteforum!
tacman's Avatar
Fit like stock! Great traction. Car used to go sideways in second gear with Goodyear SuperCar tires. Now there's barely a chirp.
tacman is offline   Reply With Quote
Old 03-02-2013, 12:17 PM   #9
thethrillofspeed
CF Senior Member
thethrillofspeed's Avatar
Send a message via AIM to thethrillofspeed
That is what I run, very happy with them. Looks better and stick MUCH better.
thethrillofspeed is offline   Reply With Quote
Old 03-02-2013, 05:11 PM   #10
Flatlander
CF Member
Flatlander's Avatar
I run the 555R-II on stock wheels. Great tires.
Flatlander is offline   Reply With Quote
Reload this Page Nitto 305/35/18 555R?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
