[Z06] Is this a good buy?? 02 Pro-charged Z06
Here is the Info, please let me know if this sounds like a good deal, i'm new to corvettes, but am familiar with the ls6 thanks to my old cts-v.
He wants 27K.
-Clean Title
-54K Original Miles
-CA SMOG LEGAL! Passed with flying colors last year.
-Car made 520rwhp.
-MSD Wires w/ Koolsox and NGK Plugs (changed less than 1K)
-CARB Legal P1SC Procharger with upgraded A&A Bracket and quick drain line.
-Custom Treadstone single front mount intercooler.
-224/228 Competition Cam with 112 LSA
-Competition Cam Upgraded Valvetrain
-4.00" Pulley make about 10 lbs. of boost.
-Dual Nozzle AIS Methanol Kit (Windshield wiper reservoir used to store methanol)
-160 degreet thermostat
-60 lb. fuel injectors.
-Racetronix fuel pump booster harness.
-LPE 255 Fuel Pump.
-DMH Electronic Cutouts.
-MSD Two-Step
-RSD Linelock Kit.
-Hurst Short Shifter.
-Skip shift delete.
-Lowered on stock bolts.
He wants 27K.
-Clean Title
-54K Original Miles
-Car made 520rwhp.
-LPE 255 Fuel Pump.
-MSD Two-Step
-RSD Linelock Kit.
-Skip shift delete.
Cruise-In VII Veteran
you'll spend an easy 8k in parts to dupe that setup; find out what shop did the work.
not a bad deal if the paperwork/title/history checks out.
Treadstone IC?
MSD 2 step, what ET is the car running??
Treadstone IC?
St. Jude Donor '13
i got a lot more money into my car then that setup. i would ask for less then 27k. i would pay 22-24 for that car if it all checked out and it ran great.
That's too much $. If I were you I would buy a nice relatively stock Z and mod myself exactly the way I wanted rather than buying a car someone else beat on and maybe did half azz work on or cut corners. Btw tread stone intercoolers are awesome intercoolers
Yeah that seems way too much, especially with that mileage. The 2 step / line lock mods would scare me - sounds like it has seen a lot of track time. And I don't even see a clutch in the list, hopefully he isn't still running the stock clutch!
I don't think 24k would be a bad deal pending the clutch.
Cars running 10 lbs a boost scare me a little bit but this one has meth so as long as he kept the meth going it should be fine.
Racing
As long as the work checks out it'd be a nice car to pick up although I would haggle him down a bit,. That's a very conservative tune for 10psi + meth and only putting down 520whp.
My bigger concern is the Pro-charger. How old is it? How many miles are on it? I bought a used C5Z with the same model Pro-charger. After a putting a mere 30K miles on the unit (total miles were around 40K), the Procharger developed a bad leak. The unit was sent to Procharger, supposedly repaired. When it came back and was installed on my car, it was still leaking! Couldn't believe they don't even bench test their work.
Check the unit for leaks!
