[Z06] jba long tubes installed!
Old 12-08-2012, 04:13 AM
alend619
alend619's Avatar
Default jba long tubes installed!
Hi everyone New member first time posting just install jba long tube headers
Old 12-08-2012, 02:11 PM
PeteZ06
PeteZ06's Avatar
St. Jude Donor '07-'08-'09-'10-'11
Nice job!!
I had JBA headers on a '95 TA many many many years ago... I didnt know they were still in business.
How do you like them so far?
Old 12-08-2012, 05:16 PM
DARRYLZO6
DARRYLZO6's Avatar
Looks great. JBA headers is a good product for reasonable cost. Did you do the job yourself and are you going to get a tune too?
Old 12-08-2012, 05:31 PM
alend619
alend619's Avatar
Thanks guys .... the car dose feel little stronger now and for $650 shipped with ceramic coating could not pass it up. And they also hooked up to my stock catalytic converters....also I have no more drone with Borla stingers ! Had them installed at my friends shop because some welding was required. Not sure if I need tuning because I'm running the stock cats.
Old 12-08-2012, 10:34 PM
anothertoy
anothertoy's Avatar
Wow, I didn't know they made LT's. JBA has always made quality parts. Get a tune, it'll make a big difference.
Old 12-09-2012, 04:03 AM
alend619
alend619's Avatar
I think i might get it tuned next week... i will post you guys the results. Should i get high flow cats before the tune?
Old 12-09-2012, 08:55 AM
DARRYLZO6
DARRYLZO6's Avatar
I would get the cats and then the tune. Why leave anything on the table. Make sure you have all the principals installed so you only have to get a tune once. Tunes can be expensive!! It would be no different if you got it tuned before you installed an intake/cold air system.
Old 01-09-2013, 03:52 AM
alend619
alend619's Avatar
finally got a dyno tune at Excelsior Motorsports in Escondido with high flow cats previous owner dyno 354 to the wheels with intake but I'm not sure what kind of dyno it was maybe a dynojet for mustang dyno
base line numbers were 320 to the wheels with mainline dyno. After efi live tune 337 then 345 then 353 then final 365 whp . 45 hp gain from a dyno tuning is amazing . Kushan told me that his dyno would show lower dyno numbers. Just would like you're guys input thanks.
Old 01-09-2013, 01:44 PM
danieloneil01
danieloneil01's Avatar
So if I reading your post right the previous owner made 354rwhp then you bought it and added headers and got +11rwhp after headers and a tune?
Did you install the headers yourself?
Old 01-09-2013, 02:14 PM
tlove32
tlove32's Avatar
Different type of dyno, so you can't compare the previous owners numbers. The OP posted that his before numbers were 320rwhp on this dyno....and the final number was 365rwhp
Old 01-09-2013, 03:23 PM
skyavonee
skyavonee's Avatar
finally got a dyno tune at Excelsior Motorsports in Escondido with high flow cats... base line numbers were 320 to the wheels with mainline dyno. After efi live tune 337 then 345 then 353 then final 365 whp. 45 hp gain from a dyno tuning is amazing. Kushan told me that his dyno would show lower dyno numbers. Just would like you're guys input thanks.
Are these numbers SAE corrected? The previous owner must have had a really $hitty tune. It seems the most logical explanation for you putting down only 320 rwhp on the first pull, and then gaining 45 rwhp from a tune-only on a car with just intake/exhaust.
If the car feels smooth and strong now though, that's all that matters.
Old 01-09-2013, 04:52 PM
alend619
alend619's Avatar
The car was never tuned before just had a intake . But after the tune its smooth and more responsive for sure kushan at Excelsior Motorsports is the man!
Old 01-09-2013, 05:55 PM
danieloneil01
I was just asking since his post was a bit hard to understand. Yes all dynos are different.
Old 01-09-2013, 05:56 PM
danieloneil01
the car was never tuned before just had a intake . But after the tune its smooth and more responsive for sure kushan at excelsior motorsports is the man!
did you install it yourself?
Old 01-09-2013, 10:40 PM
anothertoy
anothertoy's Avatar
Numbers are just numbers. What matters is how it drives and that you're happy with it!! The next step is a nice cam. Lots of cams will still pass smog.
Old 01-10-2013, 01:29 AM
alend619
alend619's Avatar
no the headers were installed at my friends shop because it required some cutting and welding. Next is a set of ported heads and cam for sure. Thanks for all your input and advice guys!
Old 01-10-2013, 01:33 AM
alend619
alend619's Avatar
No i had them installed at my friends shop because they required some welding and cutting. next is a set of ported heads and cam. thanks for all your input and advice guys!!
To jba long tubes installed!
Old 01-14-2013, 03:05 AM
alend619
alend619's Avatar
Here is a video with corsa extreme
Old 01-14-2013, 09:20 PM
WannaC5Z
WannaC5Z's Avatar
What welding/cutting is required for the install? I have been a Mustang guy for over 10 years and the aftermarket with them is typically a bolt-on job. I had to pay to have my LTs installed on my Cobra because of clearance issues with the kmember. The engine has to be jacked up and supported to get them on, plus a lift is best, which I don't have. I am shopping for a Z06 and want to learn what the best mods are for real performance gains.
Old 01-15-2013, 03:24 AM
alend619
alend619's Avatar
cutting and welding because was not a full kit like kooks ,american racing, the pipes had to be cut right in front of the cat and then welded and also the engine mounts have to be removed and the steering shaft. my friend was not too happy installing them lol. this is my first Corvette and I was told that the best mods are long tube headers intake and high flow cats. Also get it dyno tuned not a email tune ...without spending a lot of cash. Good luck finding your z06
Quick Reply: [Z06] jba long tubes installed!
