[Z06] Mantic Er2 FTW!!!
Mantic Er2 FTW!!!
This single disk clutch is remarkable with TRUE stock feel. Great HP holding capacity, and lighter than stock. Would definitely recommend this clutch. Coming from a Monster lvl 3.5 in my other Z06, this shames it. Don't be afraid to commit and buy, very good product.
Glad to hear this.
A while back, when you were deciding which way to go with your clutch package.
I remember suggesting the Manic from ECS to you.
I hear the Dual set up, has even better "street manners".....
But of the course the extra $$$
Thank's for the feed back.
Honestly it outperforms it in every fashion thus far. Mantic has EASY pedal effort, Im not using an AMC either. Price is about the same for both but you have Doug here for customer service issues if they arrive. Power holding capacity is about the same between this and the level 3. This isnt an on/off clutch, it engages like stock so you can slip it. I put about 12k on my Monster with AMC. It never gave me a problem but the pedal effort was incredibly stiff. Reminded me of a cable driven Cobra clutch, but harder. Clutch is made for a street car...
Received 2,061 Likes
Just to clarify our clutches do not require an amc and there is no comparison if you had one on one clutch but not the other, especially if it wasn't adjusted correctly. The increased bore size increases the pedal effort way more than the diaphragm springs. Not sure if you know the bearing load and plate load of the mantic, but I guarantee it doesn't hold as much if it truly has a lighter pedal.
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,090 Likes
Mantic dyno tests every clutch that leaves the factory and has all the data available for what it can handle. I would be happy to compare if you have the same data?
The ER2 design is implemented to raise the clamping force substantially without sacrificing pedal feel, so you may be surprised with what they can hold.
Absolutely no issues with the ER2 rowing through the gears with 500HP to the wheels!
I'm not in here to bash another's product, just defending my product. Doug I am not at liberty to share that information, but as far as dyno numbers are concerned we have held 1111rwtq on our dyno with a Monster Single.
By no means am I trying to stir the pot...........but what 60' has the Mantic produce so far ?? Or 1/4 mile times in general ??
Also, how would you rate the Mantic to the RXT ?? Assuming same flywheels.......
Thanks............
Anyone ^^^^^ ???
Also, what is the base and conductor material in this Mantic ??
Thanks.......
Thanks............
Anyone ^^^^^ ???
Thanks.......
Glad you are enjoying your Mantic. I switched from an RPS to the Mantic dual last year and couldn't be happier. The street manors are amazing, I can take this car anywhere now and not worry about being stuck in traffic. My fiance can also now drive my car as easily as any stick car she has driven. I have about 5000 miles on mine now with zero issues, just keeping the clutch fluid clean it feels like the day it was installed. Mantic is the real deal. Enjoy!
I have the er2 mantic, and i do feel that is is a tad stiffer pedal effort over the ls6 clutch. I had a tick master on both the ls6 clutch and the mantic. About 900 miles on the mantic so far. It does engage smooth, but rather quickly, but the tick master does exaggerate it some.. i took 500 easy miles on break in, but can tell u i can get the mantic shatter a smige.. u can barely feel it.. over all im happy.. mantic rates the single @ 780 trq btw..
Thanks............
Anyone ^^^^^ ???
Thanks.......
Thanks............
Anyone ^^^^^ ???
Thanks.......
There are several guys running the Mantic clutch in the "Mantic clutch GM EFI series @ Raceway Park", some in the tens, but honestly I have not paid that close attention to the 60' times produced.
I am confident from my experience as the shop who has produced the fastest 60'ing IRS Corvette on the planet, that the slip capabilities of the Mantic are very conducive to launching well. However if you are a regular drag racer then I'm sure you know too that the one with the fastest 60' time, or best ET is not always the best clutch for street use, or the fastest car, but often is just the one who spent the most time at the drag stripe to achieve it.
99% of our customers however are more so looking for a clutch that is not a leg press machine while holding the power they are producing. The Mantic has full filled that very well as you see from the replies in this thread.
I will certainly not make a comparison between the two clutches, that is simply unprofessional on my part if I was to do so, sorry. I'm sure they are both great clutches, we prefer the Mantic line.
The Mantic is a dual material clutch disc, it has a std organic facing ring in contact with the ER2 pressure plate and a segmented ceramettallic facing on the flywheel side. Thus making a good blend between a street clutch and an all out drag clutch.
If your intension is strictly drag racing and 60' times, I would recommend going with a slipper clutch that will require constant adjustments, and a dog bone trans for no lift shifts. I highly doubt that would go over well with the average Corvette owner quite how this clutch does though.
I hope that answers your questions, thanks for your interest in Mantic clutches.
I don't track my car so the Mantic ER2 is perfect for me and my LS3.
You guys did a great job (as usual) installing the clutch.
Lsoholic just to expand on your points made in the performance results section as we've been designing clutches for over 5 years and do test all products rigorously before releasing them to the public. I can attest that a dual friction clutch is only as strong as it's weakest link, being the organic side it will act like a stock clutch which is also organic. Some say an ls7 will hold 600rwhp...statically maybe, but abused don't count on it.
