[Z06] >>>List of C5Z06's with failed valvesprings, not always high mileage<<<.....PICS.
Okay, so I have an o2 Z06 with 27K on it that I just had a Magnuson TVS2300, Kooks Lt and X pipe installed. Motor is now close to 600 H.P. The rest of the motor is stock. I am thinking I need valve springs soon! I also plan on a cam upgrade in the future so can I get springs that will be compatable with my new cam and install them now? Also, I have a 99 coupe with 66K miles on it, stock as far as I know but I don't know much about the cars past. I have owned it for 7 or 8 years now, but as far as I know it is bone stock. It that car at risk also for the valve spring issue?
2002 Z06 Build date 5-02 98,000 miles stock yellow springs. Changed them to pac 1218s for peace of mind. As far as i no the car is bone stock. Last six of my VIN 131164
2001 and 2004 model years don't seem to have this problem (at least it's not nearly as prevalent as in the 02-03 years). But this was the entire point in starting this thread... to hopefully identify a range of VINs that were most affected by this issue.
A detailed valve spring study that supersedes this post can be found here:
c5-z06-discussion/build-date-vin-analysis-of-ls6-valve-spring-failures.html
#34
I was quoted about 3hrs to complete the job so about $300 + parts. All in it was gonna be about 750+ tax (cdn) so i ordered everything i need an am going to do it myself including new plugs and wires for about $300.
#35
Just to clarify for others - a stock replacement spring swap alone won't cost $750. It should be in the $300-$550 range, depending on labor rate and choice of springs.
#36
Well.... damn it then! I guess that I'm driving around now in a ticking time bomb waiting to happen!!
I have had problems now with the last three sports cars that I have purchased now.
My first was a 97 Eclipse turbo that I modded and I had to worry about crankwalk all the time before I sold it, but it never happened thank God but I still had to stress over it.
My 03 Subaru WRX that I now have were known to have glass tranny's in which I broke 2nd gear and had to go with a re-advised gear set from Subaru which set me back $1500
My 02 C5 Z06 has friggin problems with a bad batch of valve springs!
Jeesh... If I don't have bad luck I don't have any luck at all.
#37
#38
And remember, even if 1 out of 25 cars was affected in a given run, that means 24 out of 25 were not affected. But, ~$400 in preventive maintenance seems like a better idea to me then playing Russian Roulette, even if the odds are in your favor.
#40
i just got my 03 ZO6 back on the road last week. broke the intake valve spring on #5, dropped the valve, put a hole in the piston, wrecked the head, cracked the block, twisted the rod. i dont have the build date but the last 6 are 124110.
